KX250F Monoshock in KLS250S - Possible?
Old Mar 12, 2020 | 02:25 AM
andyng's Avatar
Default KX250F Monoshock in KLS250S - Possible?
is it possible to fit and use a KX250F monoshock in a KLX250S?
Old Mar 13, 2020 | 02:08 AM
What's the eye-to-eye length of both shocks? It's almost certain that the geometry of the linkage and how it affects damping are very different. If the shocks are the same length and you can get the eye bushings to match the KLX, it's likely going to need revalving at the least. I'm thinking a late model KX shock is going to be longer based on the longer travel, but I don't have one in hand to check.
I'd be inclined to revalve the KLX shock either yourself or by a source that performs it. The rear shock on the KLX is actually pretty good and responds well to a revalve. It's the fork that's the weakest link.
Josh C
Apr 28, 2020 08:00 PM
klx199
Feb 16, 2013 04:21 AM
djchan
Dec 18, 2012 11:28 PM
Fourty2ri
May 30, 2009 02:02 AM
ms.gray
KX65
Sep 7, 2007 04:28 AM
