KX125 clutch plates, clutch will not release.
Old Aug 14, 2015 | 01:09 PM
taxonomy's Avatar
Default KX125 clutch plates, clutch will not release.
I rebuilt my clutch using the KX125 plates that have been recommended here and on Planet KLX. After the rebuild the clutch will not release. I am pretty sure I got it together all right. I used Barnett springs.
Has anyone used KX125 plates in their KLX clutch?
Is there some obvious reason that the clutch will not release? No mater how you adjust the cable the drive stays to the rear wheel.
Thanks
Old Aug 14, 2015 | 03:32 PM
Michaelb2's Avatar
Wish I could help you out, but I have another question: what is the advantage to using KX125 clutch plates on the KLX250?
Old Aug 14, 2015 | 03:48 PM
taxonomy's Avatar
The KX clutch frictions are better quality and have more surface area.
I think I may have found the answer, it may be true that I need to run the thinner steel plate when running the thicker, more agressive KX frictions.
Old Aug 14, 2015 | 07:30 PM
Michaelb2's Avatar
Thinner steel plates from klx with friction plates from kx?
Old Aug 16, 2015 | 06:47 PM
MattyTracks's Avatar
Did you soak the fibres in oil prior to installation??
Old Aug 17, 2015 | 02:02 PM
taxonomy's Avatar
Yes, I did it all by the book. I've done clutches before too.
The bottom line is if you want to he the KX125 friction plates you need to use the thinner steels. Otherwise the stack height is too thick and the clutch cannot release.
I ordered the thinner steel plates last week.
taxonomy
Jul 15, 2015 03:57 AM
amck
KX125
Jan 17, 2011 05:20 PM
memyname
Oct 1, 2008 01:13 PM
Gymratt500
Jun 11, 2007 12:55 PM
fewdecentwords
May 31, 2007 10:37 PM
