KX Fork Swap Nearly Complete
Old Feb 10, 2009 | 01:35 AM
Brewster's Avatar
Originally Posted by Sid Post
I'm looking at the BRPMoto (http://www.brpmoto.com/product_info....oducts_id=1533) triple clamps with the Scott's stabilizer. Should I consider larger fork tubes that are easier to find as opposed to reworking 15 year old worn out models?
What you have to be concerned about with other triple clamps is the steering stem and the bearings in the steering head. The 43mm forks bolt right into the stock triples. 46mm forks and triples require machining done to the steering stem to fit through the upper bearing.
Ride on
Brewster
Old Feb 10, 2009 | 03:53 AM
MaverickAus's Avatar
G'day Brewster, didn't know you were over here good to see you
Old Feb 11, 2009 | 02:21 AM
Sid Post's Avatar
Ride on
Brewster
Thanks again Brewster!
I was thinking about something like these:
http://www.brpmoto.com/product_info....roducts_id=702
If they can be machined or made slightly bigger, I could fit a 46 to 48mm fork depending on what I find that is cost effective.
Old Feb 11, 2009 | 05:04 AM
Brewster's Avatar
I wouldn't suggest machining out the fork bores on those to fit the newer/larger forks. It would weaken them. It would be easier to press the stem out of the newer/larger fork tripples and machine the stem down and re-thread it. I did that to a set of 46mm forks. When I tried them, they were too firm for my riding style......pokey.
Ride on
Brewster
blackettle
Jun 4, 2012 02:37 PM
3L4NS1R
Sep 24, 2009 07:51 AM
3L4NS1R
Mar 23, 2009 01:20 AM
aszrael1266
Sep 13, 2007 04:05 PM
Oct 31, 2006 06:06 PM
