KLX300 - "Unmuzzled" Power Charts Needed.
Old Aug 11, 2024 | 03:44 AM
  #201
tsc's Avatar
tsc
Originally Posted by Olderider
You need to remember these are not huge HP engines. If you want more power than 30hp you need to buy something else. These bikes have their place as tractors that can go just about anywhere. JMO
It's not about peak hp numbers. It's about power drop of the cliff suddenly at soft rev limiter. The unrestricted ECU makes huge difference.
For example I attack hill climb with wide open throttle. It's not fun when power suddenly drops at 7500rpm but your engine keeps revving.
From my experience running unrestricted ecu - it's night and day in the upper rev range.
Old Aug 11, 2024 | 06:50 PM
  #202
Olderider's Avatar
Mine pulls fine all the way up to the rev limiter with just the fuel controller.
Old Aug 11, 2024 | 09:15 PM
  #203
Nigel's Avatar
The US KLX bikes do not have the detune past 7500 rpm from what I can tell. That does not mean the timing is optimal for power, my bike with a couple mods pulls well between 5500 rpm and 8500 rpm. It will over rev to 9500 Ok if needed.
Old Aug 11, 2024 | 11:23 PM
  #204
tsc's Avatar
tsc
USA klx250 do have detune at 7500 and klx300 do have detune at 8000. You won't get 30+hp with standard ECU.
Old Aug 12, 2024 | 04:25 AM
  #205
Olderider's Avatar
I am not convinced you will get 30 with the flash.
Old Aug 12, 2024 | 04:48 AM
  #206
tsc's Avatar
tsc
Looks like my posts are not clear. My ECU is NOT flashed. I use OEM unrestricted ecu.
If you want learn something I encourage you to read through my thread where I was adding mods and dyno each of them.
https://www.kawasakiforums.com/forum...e4/#post558717
Current set up with 31 hp on the dyno:
- OEM Kawasaki klx250 ECU for japanese market (JDM)
- piggyback fuel controller
- full exhaust
- open airbox
Old Aug 12, 2024 | 04:50 AM
  #207
tsc's Avatar
tsc
Don't confuse soft rev limiter (8000rpm) where ecu starts cutting ignition and stops making power and hard rev limiter (10000rpm) after which engine doesn't rev.
Old Aug 13, 2024 | 02:18 AM
  #208
Olderider's Avatar
Dyno numbers are just that. Numbers,,, all dyno sessions are different so they really mean nothing to me. I don’t need to read through your thread because it really doesn’t matter to me if it makes 25 or 31. There is just not enough power available for the money you need to spend. Might as well buy a bigger bike to be begin with. JMO that’s all
I like my bike the way it is. No reason to spend even more for not much return that can never really be proven. Again IMO
Chmerr
Apr 12, 2024 02:26 AM
fenderworks2
Mar 7, 2014 03:03 AM
RaceGass
Jul 8, 2011 08:55 AM
SlapDrum
Mar 31, 2009 07:30 PM
klxcrazy
KLX300R
Jun 25, 2006 10:25 AM
