Klx250sf cam chain too tight on "new" engine
Old Aug 24, 2015 | 03:20 PM
Ruggybuggy's Avatar
Originally Posted by DYNOBOB
The valve springs may be acting on the cams to keep the chain taut across the top.
Not on mine, mine was on a compression stroke when I took it apart.
Old Aug 24, 2015 | 08:56 PM
Originally Posted by Ruggybuggy
How much force does that spring apply? When I did mine the slack side was tight with the slightest amount of movement. When I posted my concern someone posted their's was similar so I just went with it. No problems so far.
Vagueness of terms... back run was tight with the slightest amount of movement, how much movement, how tight is tight. Suffice it to say when I did work with the cams doing the MCM the cams had to be pulled out to move a tooth, not enough play to move the chain without doing so. As long as there is some slack, the cam drive is good, providing it will turn over at least a few rotations by hand (ratchet/socket on left side crank bolt) after reinstalling the tensioner. Proves it is seated in correctly and nothing is holding it up or jamming in the sprockets. Turn counterclockwise, pulls on the front of the cam drive.
If using the OEM tensioner, pull the cap and remove the spring, pull back the ratchet pawl and push the plunger back in - then reinstall put the spring back in and put the cap bolt back on. If using a manual tensioner, back it out, install it (should not be pressing on the slider yet), then adjust it.
pwjm
Jun 11, 2015 02:27 PM
outrecording
Jan 1, 2015 11:32 PM
work
Feb 6, 2011 02:06 PM
zzrotceh
ZZR 600
Feb 1, 2011 06:23 PM
davehayward1
Sep 20, 2010 07:28 AM
