KLX250s for us bigger guys?
Dropping the gearing improves 6th gear acceleration and makes 3rd gear more punchy for exiting corners and perfect for faster trails. 1st gear can be used without the clutch as a slow walking pace. All this at the cost of fuel economy and crusing comfort. Although the motor is so smooth at higher revs, it's not a big difference.
ORIGINAL: motoguy128
The 13T is a good improvement. Probably the best compromise if you're goingot use it a lot on the street. If you're doing a lot of trail use, 13/45 is the better way to go. Some guys even go lower and use a 13/47. The stock KLX300R has a 14/48 or a 14/50 I believe because it's designed for trail use. I just added the 45T in the rear and new chain but haven't tried it out yet (waiting for it to warm up outside this afternoon)
MIPLAYSTATION
Dec 5, 2006 08:50 AM
LordVngr
Sep 24, 2006 06:03 AM
