Klx250s Headlight
Old Jun 6, 2020 | 06:53 AM
Tristan Nelson's Avatar
Default Klx250s Headlight
Hi,
I have just purchased a 2017 KLX250s and sometimes when I turn on the key the headlight doesn’t work. Usually I then start the bike and within say a minute of running the headlight comes on and works normally? It doesn’t seem to be loose wires or anything, because once it’s on it’s on.
Has anyone got any advice please?
Old Jun 6, 2020 | 02:56 PM
azdeuce's Avatar
I would take out the bulb and try a new one...
good time to upgrade to LED
if that isn’t it check wiring possibly ground
Old Jun 6, 2020 | 09:05 PM
ALONEINTHEHILLS's Avatar
Check and clean the contacts in the high/lo beam dimmer switch. I'd guess some mud or corrosion is on the low contact. You could also just turn it to high and see if it doesn't do it with the switch in that position.
Old Jun 7, 2020 | 10:14 PM
Default Solved
Hi thanks for the advice.
i managed to locate a loose wire at the main connecting plug behind the radiator. All good now!
thanks again
queen of spades
May 31, 2017 10:34 PM
dcisp250
Ninja 250R
Jan 14, 2008 02:15 PM
batang city jail
Ninja 250R
Jul 26, 2007 10:50 AM
fastex500
Ninja 500R
Mar 7, 2006 09:11 PM
