KLX250 stalling
Old May 22, 2014 | 02:57 AM
Dugualla's Avatar
The kouba screw was tuned according to the included instructions; ended up being just over 2 turns out.
Old May 22, 2014 | 05:57 AM
Papua Man's Avatar
sounds a bit like water in the fuel. coming from a place with 400 inches of rain a year I deal with something that sounds similar... cross a river, suck in a splash, bike will run but when you try to put load on it sputters and stops....
Old May 23, 2014 | 06:17 PM
Dugualla's Avatar
Ran all new fuel through the system, stalling is still there. Is there a way to test the CDI ignitor box for proper operation?
Old May 23, 2014 | 07:17 PM
Yup, put it on another same bike and see what happens. I blew a CDI recently and that's how I checked mine. My co-worker has an '07 and I diagnosed my toasted CDI by putting it on her bike.
There may be other ways, but none I'm aware of.
Old May 30, 2014 | 03:18 PM
coltfourfive's Avatar
Same symptoms for me a few weeks ago.
My fuel filter was not seated correctly and a small piece of debris got caught in the main jet.
Old Jun 28, 2014 | 08:42 PM
Dugualla's Avatar
Default Update
It turned out to be a clogged main jet. When I cleaned the jet before, I failed to notice the debris that were in the bottom of the bowl. Jet became clogged again, bike ran poorly.
Old Oct 23, 2014 | 10:06 AM
Si Bax's Avatar
Check the water in both rads the second rad has a bleed cap take if off when you fill it up my friend had the same problem he stripped the carb changed the CDI replaced the coil and lead plus plug AND THEN found there was no water in the second rad so the sensor was cutting the bike out - It may work it did for my friend
rbray
Aug 8, 2007 08:11 PM
sajeed
Ninja 500R
Oct 5, 2006 11:01 PM
spaceman
Jan 7, 2006 08:47 AM
frank80
Jan 7, 2006 08:06 AM
sajeed
May 27, 2005 06:53 PM
