klx250 efi mods and their impact with dyno
Old Dec 31, 2023 | 10:21 AM
Klxster's Avatar
Your AFR is too lean. Maximum power levels cannot be achieved unless/until you create 12.5 - 12.8 across the board.
Old Dec 31, 2023 | 04:42 PM
tooter's Avatar
Originally Posted by tsc
Today I've made another dyno with following mods on top of KDX snorkel
  1. 2.5kOhm NTC in series in IAT to add more fuel.
  2. Modified stock exhaust muffler. I've removed "straw" end pipe and replaced it with 2.5cm stainless steel pipe. I followed the process shown in this video. It was quite difficult to remove the stock end pipe from the muffler - took about 30 minutes back and forth. I'm very happy with the sound though - it's still quiet (I measured 90dB), but more pleasant. You can check my video here. I do feel exhaust flows much better - the air stream pressure after exhaust tip is much stronger compared to stock straw.
The dyno (top-down on the chart):
  1. Red - KDX snorkel, modified exhaust, NTC
  2. Blue - KDX snorketl, modified exhaust (no NTC/IAT modification)
  3. Pink - KDX snorker
Observations:
  1. According to AFR chart NTC added less fuel than I expected. AFR is basically just little bit rich.. Maybe the relation between IAT and additional fuel is not that linear I assumed.
  2. Without fuel correction there is no power gain in modifying exhaust. Power torque lines are basically the same.
You did absolutely BEAUTIFUL exhaust work!
It sounds SO much better and you kept the original factory look. It's likely that with fuel tuning you can realize some power gains. I also experiment and modify my exhaust so I know how much fun it is.
Old Jan 4, 2024 | 12:00 PM
da2's Avatar
da2
klx300 and 250 ebu are not same.
Indonesian manufactured klx are castrated.
I hawe japanse manufactured klx250s
Year 2016
iInjected
24 hp at 9000 rpm
Ignition at 11000 rpm 39 degree.
Old Jan 4, 2024 | 10:49 PM
tsc's Avatar
tsc
Year 2016
iInjected
24 hp at 9000 rpm
I would not call it castrated. 22hp is pretty typical for EFI klx250.
There is also ninja 250SL here which use same 250cc engine, but produces 28hp/22.7nm torque. I've done some research about differences of the klx and ninja 250sl engine set ups. Interestingly even camshafts are same (or very similar)! Part number for camshafts for 2021+ klx300r and 250sl are same.
The differences I found so far - larger 38mm throttle body on ninja and possibly different ignition system.
Old Jan 5, 2024 | 12:25 AM
tooter's Avatar
28 horsepower is really good for a 250, except the Ninja's curb weight is 379 pounds.
I'll gladly take the reduced engine power as my curb weight is a nimble 288 pounds. That's 91 pounds, or 24% lighter. On small bikes, weight matters. And reducing it has the same effect as adding more horsepower.
Old Jan 5, 2024 | 05:02 AM
da2's Avatar
da2
25% is big diference
And another ignition makes it flexible
And gives you more impact when you mod your bike
Old Jan 5, 2024 | 12:07 PM
da2's Avatar
da2
And you cant add more fuel whit temperature sensor
Its oxygen sensor here.
Its open loop and closed
Maybe for testing you need plug off cooling temp sensor.
then your ebu turns in to open circuit mode.
If its works then you need another cooling way
​​​​​​​Sorry for my english ))))
Old Jan 19, 2024 | 12:07 PM
tsc's Avatar
tsc
I've installed 292cc AHL kit, removed secondary throttle plate and corrected AFR with fuel controller (not ideal though - a but rich at high RPM).
As of now mods are following:
  1. KDX snorkel
  2. modified OEM klx250 exhaust muffler (replaced end cap with 2.5cm / 1 inch pipe)
  3. 300cc AHL big bore kit (great quality and fits bolt on! no need to modify chain tensioner)
  4. Fuel controller (about 30% fuel added across the whole RPM range)
I'm happy with the result ~26 hp and 26.5 Nm (19.5 lb/ft) of torque from the wheel
Old Jan 19, 2024 | 01:04 PM
da2's Avatar
da2
Nice work
Theorerical its rich at high rpm because ignition timing .
Can you tell me your ecu part number?
Old Jan 19, 2024 | 01:08 PM
tsc's Avatar
tsc
Nice work
Not sure about exact number. You can try find in catalogs - Indonesia klx250, 2022.
But as per user manual ignition is 5 degrees at 1300 to 34 degrees at 11000. So it's retarded compared to Japanese 39 degrees.
