KLX250 Carburator
Old Mar 7, 2021 | 03:15 PM
alvitdk's Avatar
Default KLX250 Carburator
Hi, first of all thanks for letting me join, Thomas my name from sunny Texas. I run into an interesting issue with the carb of my daughter her 2007 KLX250H (or S I guess) leaking from the carb and really having a tough time to start Taking it apart, float is working fine, replaced the fuel needle and cleaned the whole carb, all needles and bowl, new gaskets. However, it started great right after but sitting for a couple of days, it will not start, and leaving the petcock open will slowly leak at the overflow. Might be the needle valve seat but it's not replaceable. To make it short, I tried purchasing a new carb from ebay, as a OEM is too expensive for her, and I could not find a place having it anyway. All the ones that are listed as compatible do not have the throttle positioning sensor mount and are capped off, without even having attachment points for it.....what am I missing as I run out of ideas. Thank you....
Old Mar 7, 2021 | 09:06 PM
durielk's Avatar
Turn the gas off and run the bowl dry at the last ride of the day, I don't see a problem.
Old Mar 11, 2021 | 03:40 PM
reinigef's Avatar
Yes, turn gas off using tank petcock and let it idle until it dies.
RA091124
KDX200
Aug 29, 2020 07:20 PM
BKLR650
Aug 28, 2019 11:53 PM
starduster
Jun 26, 2016 11:48 AM
Arickrock
Jan 20, 2014 10:23 PM
Greenshirt
Aug 13, 2012 12:01 AM
