Carb Help Needed
Old Jul 19, 2019 | 06:29 PM
BKLR650's Avatar
Default Mikuni Carb Help Needed!!!
Greetings fellow Kawasaki owners.
I've been a KLR650 owner for about 1.5 years and am really enjoying it. Just upgraded my son from a 125 dirt bike to a 2007 KLX250S.
On his KLX250S, carb leaks gas when petcock is left on (black hose that connects to bowl), so culprit is the needle, seat and/or float. I plan to replace all of them while also cleaning it out.
Carb is a Mikuni T36 88A, and I can't find the correct parts. Tried jetsrus.com and for this year and model bike, the listings all show rebuild kits with a different shaped bowl gasket.
Already tried bending the float part on which the needle slides, it helped but didn't completely solve the issue.
1. Is this the stock carb?
2. Is this carb perhaps also known as a "TM36", or are the T36 and TM36 different? Or is there a cross reference model number I can use instead?
3. Where have you found parts for this carb? It runs great otherwise, just need to stop the fuel leak (even though turning off petcock isn't a bad habit).
Old Jul 19, 2019 | 06:38 PM
Kwak's Avatar
I know the answer to question No.1 - NO
Old Jul 19, 2019 | 06:41 PM
BKLR650's Avatar
Thanks, just found this and still researching:...
https://www.jetsrus.com/carburetor/c...iew_parts.html
Old Jul 19, 2019 | 07:04 PM
Brewster's Avatar
The Mikuni TM36-68 is a common swap on these bikes.
Ride on
Brewster
Old Jul 19, 2019 | 07:27 PM
GBAUTO's Avatar
This is the kit that fits my tm36
Old Jul 19, 2019 | 08:03 PM
BKLR650's Avatar
Cool, that's the same kit I found. Ordering it today.
Also, the left side of the engine has a "B&B" decal just like the pic at the link below, so apparently it also has a bore kit. Which helps explain the upgraded carb.
http://bandbcyclerestoration.com/Home_Page.html
Old Jul 20, 2019 | 09:28 PM
GBAUTO's Avatar
Look for #'s hand stamped on the cylinder exterior. Bill #'s his BB kits
Old Jul 21, 2019 | 03:30 AM
BKLR650's Avatar
Yep, I sent Bill and email and he gave me his number. Very nice of him, but unfortunately my bike has the 331 kit which is not serialized, hence no records of when it was purchased. No issue, just trying to learn what I can about the history of this bike.
Old Aug 28, 2019 | 11:53 PM
KLX_boy's Avatar
The carb that comes stock on KLX250's is the Keihin CVK34
Rustic69
Oct 30, 2017 03:34 AM
KHPower
Sep 6, 2016 05:16 PM
cleandirt
Mar 24, 2015 02:35 PM
Richard Avatar
Nov 2, 2013 12:24 PM
Greenshirt
Aug 13, 2012 12:01 AM
