KLX for touring
Old Sep 5, 2008 | 04:22 AM
  #41
dr_claw's Avatar
There is about 4500 miles on my bike so it is time to check the valves.
I have done a couple 300-350 mile rides. I l moded the rear rack and welded it a little longer with a big square bag. The inside of the bag is lined with 3/16" aluminum and bolted through the bag.
Not too bad so far
Old Sep 5, 2008 | 07:51 AM
  #42
tremor38's Avatar
Originally Posted by jonathanneely
I've had ZERO performance problems from simply removing my snorkel on the airbox. ZERO
You might be OK as long as you rejet before adding a slip-on or full aftermarket exhaust.
The thing is, you won't encounter 'performance problems' unless you are way off-the-chain lean...ala removing the entire airbox lid, but performance related problems aren't the only worry.
In a lot of cases, the engine will seem a bit more peppy when running somewhat lean, but what you don't see is what is happening inside of your combustion chamber...chances are it's burning hotter. That's why Wedge reported burning up his spark plug. It won't happen over night, but the added heat can do damage.
That's why racers tend to run things a bit on the rich side.
Old Sep 5, 2008 | 08:20 AM
  #43
tremor38's Avatar
Originally Posted by 09KLXowner
someone said that the '09 wouldn't be able to pull a 15-toother, think it was tremor. others said it may have trouble. I disagree totally. The 2009 KLX's transmission was beefed up over the old bike. The gear ratio for 6th was lowered and brought closer to fifth making it more usable.
That's a good point. Here are the ratios of old and new. In any account, it wouldn't cost much to get a 15T and find out. It appears that 3rd and 4th gears are farther apart on the 2009 while 5th and 6th are closer together.
Gear--06/07 ratio---09 ratio
1st---3.000 -------3.000
2nd---2.000--------2.000
3rd---1.500--------1.500
4th---1.250--------1.190
5th---1.050--------1.050
6th----.904---------.952
Old Sep 5, 2008 | 09:38 AM
  #44
pseacraft's Avatar
Originally Posted by je2000
Nice. Now what will be interesting is what will running a FI computer mod, airbox, and pipe do compared to jetting, airbox and pipe on the "regular" klx's.
I am also curious about what my options will be. I already want to swap the pipe. But with the FI I am very ignorant and will be looking at learning what my options are. When I get the bike and dirtbagz setup I'll post a follow-up here, then I will open a thread looking for FI mod thoughts.
Eric
Old Sep 5, 2008 | 10:22 AM
  #45
tremor38's Avatar
Eric
I haven't seen what adding just a pipe will do, but a local Japanese magazine tried opening the airbox on the EFI KLX and it actually lost power. That tells me that the bike needs the equivalent of a Power Commander to properly remap the mixture.
I have emailed a company named Blue Lighting Racing here in Japan about that subject. They told me that they are adapting their ICON II controller for use on the KLX250s/D-tracker and that it will be ready "soon." This is the same unit that the local Japanese use for re-mapping the WR250X/R.
The last time I visited their website, they had actually entered 'KLX250/D-tracker' on the last line of their compatible Kawasaki model speadsheet, but there's no data or price next to that yet, so I'm thinking any day now.
Old Sep 5, 2008 | 04:50 PM
  #46
09KLXowner's Avatar
Banned
someone looking into a new fi d-tracker....tremor?
Old Sep 5, 2008 | 10:10 PM
  #47
tremor38's Avatar
LOL!
Naw, just too much time on my hands with all of the rain we've been getting.
I'm too attached to the one I've got. I'd just like to see more people here in Japan riding the new one, but I'm pretty sure they'll be shying away from it until they can do something basic like adding an aftermarket exhaust. Either that or they've already bought the WR.
Being a tinkerer at heart, I looked into what it would take to convert to EFI, but there's way too much involved with that.
Old Sep 6, 2008 | 02:08 AM
  #48
WestOzKLX's Avatar
I'm with Tremor on this one. Running a tad rich is the way to go. I'm running a #138 main and the bike still performs. Lean leads to hot spots, leads to "pinking", leads to damaged motor. It doesn't happen overnight, but it does happen.
Boglor
Aug 29, 2012 08:48 PM
kevlarian
Ninja 500R
14
Nov 15, 2006 08:49 PM
speed2101
Jul 20, 2006 02:11 AM
Ron30014
Ninja 250R
Jun 6, 2006 05:31 PM
jwach1
Ninja 500R
May 4, 2006 02:46 AM
