Klx top speed and climbing ability?
Where can I order the 45 tooth rear from? I looked at AFAM and it was $57.00 for an alloy rear 45 t sprocket for the klx 300, but they only had 47-50 tooth selection for the steel ones which only cost $37.00, are there any alternatives? Or should I just go ahead and get the alloy one, also I have to get a 108 chain right? Or 109?
ORIGINAL: incabiker
So will this bike pull much better if I put the 45 t rear sprocket on and just leave the front 14? That will give me a ratio of 3.21. Since this is my 1st bike I am pretty used to how it feels on trails and whatnot, but I need more pulling speed in 6th. I don't mean I want to accelerate like a bat outta hell in 6th, but I want to be able to just keep the RPMs consistant without dropping off when going up hills. I also don't want to lose alot of top end speed because I have to get on 2 lane highways to get to any trails close to me, and thats a 65 mph speed limit which really means 75 to all the cars, so this sounds like it would be a good compromise by giving this bike more power while not dropping the top speed too much.
all of you people with 13 t fronts and stock rears should be able to answer this one ok. Does it at least keep consistant RPMs in 6th while going up a hill?
I've hit 95 on the speedo, but that was with the help of a little Kansas tail wind (read 30mph steady wind
). Same road, same day, same wind, going the opposite way - I could only hit 75 on the speedo. My top speed did not change going from stock gearing to the 13-tooth front.
ORIGINAL: dazjr
Greetings all
I have been reading around on the web to learn a little about this new klx250s & as such have landed here.
Would you guys say that the klx is fairly smooth vibe-wise for street use at cruise speeds (wife's question)?
My wife & I were agle to check one out at a shop in FL. I want it for her but I know that I could have huge fun on this bike myself.
I am excited about this bike & hope the market for this level of machine will grow here in USA.
So far it's been the drz's have been the only big four bikes at this level & the 400 is too much for her in more ways than motor only.
I have an 86 tt350 yamaha that's tagged & she will use this for a while but hopefully in the near future I can turn this with some other things into a the Kwaker.
Thankyou...Steve F
Thankyou...Steve F
At 220 lbs with gear, I found the stock bike with stock gearing to be unable to maintain speed in 6th gear if there was any grade or headwind to speak of.
Todd
Todd
ORIGINAL: bmwhd
Todd
Todd
ORIGINAL: chainslack
Greetings all
Thankyou...Steve F
Greetings all
Thankyou...Steve F
With over 300 lbs represented by my wife and I, the bike will reach and maintain 75 with no trouble. I do have to say that in South Dakota, there aren't many hills... Love the bike and think everyone should own at least one. I'm excited to get it back to Idaho in May for some high desert and mountain play.
ORIGINAL: navyman
