KLX Lowered - Need a Shorter Stand
Old Jun 25, 2008 | 09:44 PM
NL_KLX250's Avatar
Default KLX Lowered - Need a Shorter Stand
Anybody know if you can get a shorter kickstand for the KLX? I have mine lowered so my wife can ride more comfortably, and now the dang kickstand is just a touch too long. In the wrong situation, the bike would likely fall over on its right side I really don't want to chop it. Is the stand adjustable even, that would be sweet.
Thanks in advance for any and all replies!
Old Jun 25, 2008 | 10:52 PM
f1rocco's Avatar
Default RE: KLX Lowered - Need a Shorter Stand
Have a buddy hit it with a torch and slightly bend it...1/2" at a time..Cool it off with a gallon of water................
Old Jun 26, 2008 | 01:24 AM
RaceGass's Avatar
Do your self a favor, go and buy a new one modify it and then show it too her when its done. You'll be a HERO....and she will probably make you Very Happy in return. Then go buy the next thing on your hop up list.
Think about it Work it HERO
When you bend it outward it sticks out when tucked up lookin way funny, buy a new oneandshorten the one on the bike.
Old Jun 26, 2008 | 01:38 AM
tconnell's Avatar
Just for your information. I don't think there is a commercial shorter one. I had the same problem in it being way too long after lowering the bike. I removed the entire kickstand and took a hack saw and cut through the leg as close to the botton plate as I could. Then I cut off about 3/4 inch of the leg as close to the angle that I cut the plate as I could judge. Took it to a guy in our club who is a metal worker. Took him about 5 minutes to re-weld it to the leg.
I ground it smooth here in the shop. Hit it with a wire brush to rough it up and cleaned it with Acitone. Applied two coats of gray primer then shot two coats of a semi gloss Crackle finish. No one knows it's been shortened as it looked new... until I had it in the dirt for a few hours. But it does stand up now with no hint of falling over.
Just a thought. Be safe.
jimmy101
Feb 13, 2011 09:09 PM
JonnyD
Jul 16, 2008 07:22 AM
nin6
Ninja 250R
Apr 2, 2008 10:38 PM
kgwld1
Aug 18, 2007 09:50 PM
Bad Bear
Oct 26, 2006 01:49 PM
