KLX to EXC
Truck scales are flush to the ground any slight angle change will be negligible in the total due to the sheer size and volume of weight. With the bike when you sit the bike up on the scales an inch or two higher, that bit of angle will transfer some weight to the other end on the ground and it will be a bit more significant, but not massive.
From what I see, the FE250 is a two stroke? Enduro360 had it at 230 lb without gas. Guesstimate with two gallons maybe 244 lb. With all the stuff you mention 265 lb would make sense. Wish we could have them... brrrrrrrap!
Please realize my comments are totally in response to the "226 lb four stroke KTM dual sport" which appears to be non-existent in the light of day, yet these numbers get bandied about every time to lord over anyone who is on a Japanese dual sport. I just felt like popping the balloon. I know the bikes are damn good, but that doesn't make them or their owners gods and the rest of us not worthy to lay tread to the trails they ride. It just gets old.
A motorcycle has 2 contact points (3 if you have it on the kickstand) with the ground, ALL weight of the motorcycle is distributed between these 2 (or 3) contact patches. If you measure the pressure (weight) of each of the 2 (or 3) contact patches, the weight of the motorcycle will be distributed completely (but not likely evenly) across both (all 3) contact points. Measuring the weight of each contact point and then adding them together certainly should result in the total correct weight of the motorcycle.
I think that my weighing leaves some margin for error (not having both wheels at the exact same height from the ground, and not weighing 10 times and taking the average of all the weights, throwing out any obviously bad ones), but not a large margin - if I get a chance, I'll try weighing the bikes with the non-weighed wheel elevated on wood to the same level as the top of the scale, to see if/how much difference there is. Again, for me, the weighing exercise was more about the difference (even though that would be slightly affecting by inaccurate weighing methods), rather than the total. I do feel that the total weights of the two bikes are pretty close to what others have got, so I'm feeling fairly confident in the numbers, give or take a few pounds. From what I'd read, the TE250 and the KLX250S (2009+ as apparently the 2006-2007's were slightly lighter) should have been about 50 lbs difference in weight, but they felt more like 40 or a little more. I'm satisfied that the difference is pretty close to 40 lbs.
Cycle World 1/25/2010 - "total bike weight down to just 250 pounds dry."
With gas/oil it would make sense the difference is around 40 lb, but that isn't 50 lb and yours is lighter than the KTM 350 or 450 dual sport.
Uhmn.... eeyaap ... Often get funny looks when I pull off my helmet and people see an old grey haired guy, LOL...
Great video and Nice wheelies. Just supermoto converted my exc. So much fun!
http://i.picresize.com/UZk0
View Picture (1008 x 756 pixels) @PicResize.com
The knobbies are what keep me somewhat sane as it is...:
