KLX changing brake pads
Old Apr 27, 2015 | 09:45 PM
neonarc's Avatar
Here is a cross reference of all the bikes that use the same pin as the 2009 KLX250S/SF
92043-1416 PIN,HUNGER $9.41
Old Apr 27, 2015 | 11:17 PM
MaximusPrime's Avatar
For the rear brake.
There is no need to torque the JIS(philips) cover, just to tighten it, the pin is underneath.
And you probably don't need to replace the pin. Mine just needed a little cleaning up with some fine sand paper.
If the pin has grooves in it, that can hinder the pads from sliding easily, then you do need a new pin.
As to the front, take it apart, you'll see. You just need pads. Some grease on the sliders is good too.
Last edited by MaximusPrime; Apr 27, 2015 at 11:33 PM. Reason: I was talking about rear brakes only
Old Apr 28, 2015 | 10:08 AM
KLX25O's Avatar
Default thanks
[QUOTE=MaximusPrime;520192]For the rear brake.
So the pin I was worried about the whole time is just a cover for the brake pin, great!
Some grease on the sliders is good too.[/QUOTE
What kind of grease would you use?
Old Apr 29, 2015 | 01:16 AM
KLX25O's Avatar
Default brake pads
Some on the reviews on the EBC pads and DP pads lead me to believe they are not worth it.
I can get a set from Adavance Auto, but see no reviews on a KLX using $18 brake pads.
Might try getting the brakes replaced by purchasing them from Kawasakipartshouse. The front and rear brakes are about $50 some dollars a set, free shipping over $50.
2012 Kawasaki KLX250S (KLX250TCF) Rear Brake | Babbitts Kawasaki Parts House
je2000
Dec 14, 2008 12:39 PM
Motopsychoz
Jun 3, 2007 11:15 PM
GC
Ninja 500R
Apr 26, 2007 10:14 PM
dilysi
Ninja 250R
Mar 22, 2007 07:22 AM
sikanimator
40
Apr 5, 2006 08:58 PM
