When changing rotors, replace pads?
If you're putting on a new rotor or even a used rotor from a different bike, should you change the pads too?
If you use worn (but still good) pads on a brand new rotor, will it ruin the rotor?
What about if you use a new rotor with new pads, then you go put a different used rotor on? Will anything get messed up?
If for some reason your pads are grooved they will eventually transfer the grooves to a different rotor at least in theory. I swaped my front wheel with a KDX assembly and hated the brake performance but I didn't see any damage in the short time I tried it.
I can't see there being any problem unless there are extreme conditions. Small imperfections here and there shouldn't be a big deal. I've done it a few times in my day and all was fine. Now, if you have big grooves, or bevels. Thats a different story. I would say use your own judgement.
I never use sintered pads if I can help it. I try to get organic or as close to organic as I can as to not wear the rotors. Those things are expensive!
________
AMATEUR TEEN
________
AMATEUR TEEN
pads
If your pads have lots of life on them and only have some grooves in them just take a sheet of emery cloth put it on a flat surface and give your pads a quick rub down to get rid of the grooves.
