When changing rotors, replace pads?
Old 12-11-2008, 06:52 AM
je2000's Avatar
Default When changing rotors, replace pads?
If you're putting on a new rotor or even a used rotor from a different bike, should you change the pads too?
If you use worn (but still good) pads on a brand new rotor, will it ruin the rotor?
What about if you use a new rotor with new pads, then you go put a different used rotor on? Will anything get messed up?
Old 12-11-2008, 07:49 AM
MaverickAus's Avatar
I didn't, all works fine
Old 12-11-2008, 06:20 PM
je2000's Avatar
I've researched a little more and apparantly you're not supposed to put sintered pads onto a bike that wasn't equipped with OEM sintered pads.
Old 12-11-2008, 06:36 PM
GreenMonsta's Avatar
If for some reason your pads are grooved they will eventually transfer the grooves to a different rotor at least in theory. I swaped my front wheel with a KDX assembly and hated the brake performance but I didn't see any damage in the short time I tried it.
Old 12-11-2008, 07:12 PM
JasonFMX's Avatar
I can't see there being any problem unless there are extreme conditions. Small imperfections here and there shouldn't be a big deal. I've done it a few times in my day and all was fine. Now, if you have big grooves, or bevels. Thats a different story. I would say use your own judgement.
I never use sintered pads if I can help it. I try to get organic or as close to organic as I can as to not wear the rotors. Those things are expensive!
________
AMATEUR TEEN
Old 12-11-2008, 11:43 PM
WestOzKLX's Avatar
+ 1 on organic. Interchange as desired as long as there the pads remain flat ( no grooves etc.)
Old 12-14-2008, 12:39 PM
oldphart's Avatar
Banned
Default pads
If your pads have lots of life on them and only have some grooves in them just take a sheet of emery cloth put it on a flat surface and give your pads a quick rub down to get rid of the grooves.
KLX25O
04-29-2015 01:16 AM
scat
06-12-2007 03:11 PM
ZX750E1
Ninja 500R
12-29-2006 01:10 AM
Notstock
05-02-2006 10:15 PM
99illinininja
12-15-2005 01:17 AM
Quick Reply: When changing rotors, replace pads?
