klx 331 jets
Old Feb 12, 2014 | 08:11 PM
panaisnc30's Avatar
Default klx 331 jets
Hi guys.I will install a Bill Blue 331 big bore kit and i would like to know what jet the others have used for the standard cvk34 carb?I have a kn air filter and a free flow exhaust.
Old Feb 12, 2014 | 08:24 PM
Brieninsac's Avatar
There are many factors that contribute to proper jetting including mods and elevation. Here's a spreadsheet a member made that has other riders' setups. This may be a good starting point for you.
https://docs.google.com/spreadsheet/...=sharing#gid=0
Old Feb 13, 2014 | 05:09 AM
2veedubs's Avatar
^^ What he said^^ Did you rejet after your current mods? If not you must be at elevation. What is your exhaust setup? The big bore will not drastically change your jetting requirements. When I did the 331 the jetting was real close but I chose to go 1 up on the main as my bike seems to like running fat rather than lean. Welcome to the forum!
Old Feb 13, 2014 | 08:29 AM
panaisnc30's Avatar
Hi.I haven't done the mode yet.I am waiting for the new cylinder from bill blue.I just want to be as close as i can for the first ride and then i will set up the carb properly.I have a kn air filter and a free flow muffler.
Old Feb 13, 2014 | 03:00 PM
2veedubs's Avatar
Please explain what a free flow muffler is. Modified stock can? FMF? What is your current jetting? Location and elevation. Need detailed info to assist you. Did you get a chance to look at the detailed info that Brieninsac pointed you to.
Old Feb 13, 2014 | 07:45 PM
panaisnc30's Avatar
Hi!I have an after market muffler made from a brand here in Greece.It is called RaceTech.I live at sea level and the humidity is 55-60%.I still have the stock jets,120 main jet and 35 pilot jet.
Old Feb 13, 2014 | 09:04 PM
2veedubs's Avatar
A dynojet kit jetted per instructions for your mods will get you in the ballpark. With both a K&N and a freeflow muffler you may be running lean. Dynojet kits seem to err on the rich side so you will be real close when you add the 331. The best part of the dynojet kit is the more aggressive needle and also a lighter slide spring. The included jets will get you from stock to fully modded out.
http://www.dynojet.com/pdf/2152.pdf
Old Feb 14, 2014 | 03:35 AM
linkin5's Avatar
What they said, if it was my bike I'd go with stage 2 jetting per the dynojet instructions and start there. It would be close I'd think.
Old Feb 14, 2014 | 03:35 PM
panaisnc30's Avatar
Thanks guys.
kwakajack04
Dec 25, 2015 02:28 PM
spinalcracker
Feb 4, 2011 08:29 PM
Dive2you
Aug 1, 2010 08:42 PM
cpr1
Feb 9, 2009 03:28 AM
Team FTB
Apr 23, 2008 01:29 AM
