KLX 250 ( 300 ) camshaft mod by Marcelino
Old Jun 30, 2011 | 10:21 PM
  #231
Marcelino's Avatar
NO NO NO
It´s half a tooth (11 degrees ) read carefully the original post !
Don´t just turn the cams two teeth , you will destroy your valves !
Old Jun 30, 2011 | 11:55 PM
  #232
wildcard's Avatar
Originally Posted by Marcelino
NO NO NO
I think what Jim was saying is that if someone attempted to time the engine to spec using the cams with the sprocket mod done they would be two teeth out since the camshaft/sprocket relationship has changed.
Feel free to correct me if i'm wrong and my understanding of the mod is inaccurate.
Old Jul 1, 2011 | 01:36 AM
  #233
Lutz's Avatar
If someone were to go through the trouble of timing the cams by the book, they should also notice that the bolts are in the wrong holes. If they don't notice that, god help them!
Old Jul 1, 2011 | 01:57 AM
  #234
David R's Avatar
Bolts for the exhaust cam are in the intake holes. ACR is on the exhaust cam. Kind of obvious something is going on to anyone with a little expierence. I used the manual to replace the jug and piston on my bike. I took pictures of the timing before tear down. Sometimes I do it at work too. Digital is the *****, way better than my old drawings. Sometimes I wire the chain to the cam sprockets.
David
Old Jul 1, 2011 | 02:07 AM
  #235
kansas-klx's Avatar
Default Only one week ago?
As I write this there have been 5,030 posts since Marcelino first rocked the KLX250 world this time last week. Took a day or two but it really took off.
Maybe there should be some kind of cake or award presented or something.
I've had the full mod applied for a couple of days, now, and am presently messing with the air box lid to see how that will do but regardless, to all those who are unsure or waiting, it is a pretty good (and free! ) mod that adds a little pep to the lower and mid ranges. I can only speak for my 250 engine with stock 42/14 gears. Others will have to speak for the 351 and 250's with different mods/gearing applied.
Thank you Marcelino. What's next, a free mod for supercharging to 50hp?
Old Jul 1, 2011 | 05:50 AM
  #236
tremor38's Avatar
If you are rally iching for the ancient CDI you can take out one of the 3 wires with AC comming into the regulator , pass it trough a 1 to 5 transformer and voila : you have the 0 V ac ( 12 x 5 ) that you need for the CDI .
Are you sure you wouldn't opening a can or worms with that? None of the 3 phase load is distributed prior to going though the Reg/rectifier. Unbalancing the phases by loading one of them might be asking for some problems. I've been known to be wrong though Also, the stator output is 39 VAC ('wires with AC coming into the regulator')..not sure where you got the 12V figure from.
I have the DC CDI for the KLX250ES adapted to my later model KLX, and while you don't get the 40 deg total advance of the KLX300/250R, you still get an extra 10 deg over stock. A rarity here in Japan is to find the CDI for the KLX250SR, where you get the same advance as the old AC CDI's on the 300/250R's
Old Jul 1, 2011 | 05:52 AM
  #237
maninthesea's Avatar
Yes what I am saying is if someone timed it by the book after the mod(becuase they never heard of the mod) They could destroy the engine. No ones going to forget about it now becuase its the shiznit but 3 years from now when you sell the bike?? or when you give it to your oldest boy and he has one of his mates work on it with him?
I may be an idiot but I will admit that I did not look to see which holes the bolts were in ANY of the times I had the cams out. Why would I expect the bolts to possibley be in the WRONG holes on a working engine if I did not know about this mod?
I am suggesting marking the sprockets for the benifit of future owners or yourself if you think you might EVER POSIBLY have a shop work on your bike. I think you would be hard pressed to get a Kawi dealership to fix the damage if you did not alert them to the mod. Probably depends on the dealership and your relationship but good luck.
What I propose is to mark a line where the sprokets now line up with the head and put a single line thru the original. That would be enough for me to say WTF & I would apreciate
Dont get me wrong I think its a GREAT mod and plan on doing it.
Flame away.
Cheers Jim
Old Jul 1, 2011 | 06:48 AM
  #238
Marcelino's Avatar
The camshaft sprockets remain clearly marked : IN and EX . No mechanic would fall for something this simple .
Old Jul 1, 2011 | 07:26 AM
  #239
OK then we can assume there is not potential for mistake except for me. Ill mark mine.
Cheers Jim
Old Jul 1, 2011 | 08:46 AM
  #240
Marcelino's Avatar
I´m really glad you have decided to post . I think you and WestOZ have the most experience with alternative ignitors for the KLX . Please look at the WebCams vs CamMod thread , I´ve put some part numbers over there , look and see if they are correct . And now down to the dirty ( business ) :
You can take one of the phases and do as you please with it , who said the consumption has to be balanced ? Most triphasic loads are imballanced . The generator just supplies 3 independent phases with the same voltage on each and every one of them . The older bikes and many of today´s MX bikes supply only 2 phases , one with 12 V and one with 48 volts ( under load ) , and with the bike in 4000 revs ( and under load ) 14 V and 56 V .
I have put a 1X5 transformer in my earlier post out of my gut , I´m not actually sure what the loses will be on a 50 or 60 Hz transformer when it´s running in a variable frequency 150 or 200 Hz to a few thousant Hz ( I really don´t know how many poles the rotor has ) . Maybe a safer approach is to use a 1X4 transformer , see where the voltages are under load and start fromm there . The voltaje that gets to the old ignition it´s not stabilized , it varies greatly from 40-something ( at idle ) to more or less 60 at full revs .
Another approach would be to rewind one of the three phases with a smaller wire , but double the number of winds , the output voltage is proportional to the square number of winds , given the same magnetic flux ( induced by the magnets in the rotor ) .
That 40 V figure given in many bike´s service manual is measured with a digital voltmeter and absolutely no load . If the output would be actually connected to something you would get more some 12 V ac. or 14 V ac with a little revs .
The problem you comment on about the inertia of the reciprocating mases is a non-issue in the KLX250 , for example the KXF 250 has about the same mases ( lighter piston and heavier rod ) and it´s a happy reving engine up to 13000 RPM . There are a lot of engines with 35* max advance and while quite a lot heavier do not experience a power loss after 7500-8000 RPM they rev quite happily up to 9000-10000-11000 RPM . 25 degrees of maximum advance is totaly inadequate after 7000 RPM . Look at the power graphs and see where the top power would be if the graph would continue to rise up to 10000 .
Could you please try to find out something about that Keihin racing ECU ? I´m at a dead end over here , and I´m really fed up with dealers that have the " I know what´s best for you atitude " . It´s my bike and if I choose tomorow to put NOS on it it´s my choice to make not anybody´s else .
