Kawasaki KLX 250s 09
Old Nov 16, 2018 | 05:43 PM
I'm thinking you could unscrew the circular plug from the center of the left-side stator cover and see if the crankshaft bolt spins when the starter is engaged.
If the motor is spinning, put your thumb or some other soft plug into the spark plug hole and see if there is any compression at all. Or use the compression tester with the gauge removed and thumb over the hole where the gauge goes.
Old Nov 16, 2018 | 07:56 PM
FeloSaki's Avatar
There is some compression but I dont think 100 PSI... what can cause this?
Old Nov 16, 2018 | 08:55 PM
So, the KACR (Kawasaki Automatic Compression Release) causes one of the exhaust valves to open a bit during low rpm (starting). It will result in low compression readings, but I don't know how low. It should be disabled for true compression readings. This can be done by removing the cylinder head cover and carefully removing the spring from the KACR.
Other obvious causes of low compression would be valve or piston ring issues.
Elnene5678
Mar 23, 2019 11:04 AM
Jet1
Apr 26, 2017 12:23 PM
6InARowMakesItGo
Dec 5, 2012 05:03 PM
earthsurfing
May 11, 2012 11:25 PM
klxista
Nov 25, 2011 07:20 PM
