Kawasaki KLX 250s 09
Old Nov 15, 2018 | 09:43 PM
durielk's Avatar
OK ... I was thinking while on my bike ride.... answer these questions.... YES or NO
When you put the new battery in was it charged and did it turn the engine over?
If you have the fuel line disconnected, if you open the fuel switch, does fuel come out?
Old Nov 15, 2018 | 10:20 PM
FeloSaki's Avatar
Yes battery new. No I dont think the engine is turning... is spinning but nut turning. All my fuel lines are connected and and fuel switch open... also i have empty the bowl to put new gas...
Old Nov 15, 2018 | 11:36 PM
durielk's Avatar
So with the new battery, the engine was not turning over (piston going up and down), but you could hear other parts turning?
Old Nov 16, 2018 | 03:34 AM
FeloSaki's Avatar
Here is a video on how it should sound (0:45) to bear the klx250s
and here is the video on how my sounds
hope this helps !!
Old Nov 16, 2018 | 06:59 AM
peabrain's Avatar
vid unavailable....
Old Nov 16, 2018 | 01:11 PM
FeloSaki's Avatar
Now it should be available !
Old Nov 16, 2018 | 01:43 PM
durielk's Avatar
I think the starter & engine is turning. I think you have a carb/fuel issue.
How did you get the head off without disconnecting the fuel?
Old Nov 16, 2018 | 01:44 PM
peabrain's Avatar
sounds like 2 problems there
1. your starter has ben damaged by overuse (overheated from running to long)
2. sounds like low to no compression
Old Nov 16, 2018 | 01:47 PM
FeloSaki's Avatar
That's what I'm thinking.... I'm gonna open the left side to check that the starter is engaging and that is working properly...
Old Nov 16, 2018 | 02:00 PM
FeloSaki's Avatar
Do you know what should I be looking for? ... by the way thank you for your help PeaBrain/Durielk you guys rock!!!!
