Kawasaki D -tracker info help !!!im new
Old Sep 10, 2008 | 09:28 AM
tremor38's Avatar
Originally Posted by ddt1972
The blue rims also came as an option in 07, I just picked up a set on auction here last week for my bike.
Yeah, I see they skipped a few years...weird.
Old Sep 10, 2008 | 09:32 AM
tremor38's Avatar
Originally Posted by kgwld1
3 wires or 2 coming out of the cdi?
One loom coming out of the CDI that splits into 3 connectors. I know what you are thinking of. The adapter harness has 2 plugs that hook to the bike wiring and 3 smaller ones that hook to the CDI wiring.
Old Sep 10, 2008 | 10:03 AM
tremor38's Avatar
Originally Posted by shan
Hey tremor thnx alot man .. And deej Thnx for the warm welcome guys
Due to high taxes in our country most of the bikes i mean around 80% of the japanese bikes are sent in pieces the importers call the bikes spares bu they bring a complete bike n assemble them ..n here you can get a bike without any papers or anything registerd the way you want it only cos around 200 usd .. so ppl change years of bikes ..
I have a CBR but im selling it ..to get a D-TRACKER .. cos CBRs are gud for speed n showing off but a TRAKER yeah itll rok big time ..
ive checked sum bikes //there are sum which has the blue rim n the normal rims does the year differ from that ,
and tremor .in your 2006 the rear tail (FLAP ) is straight or a l shaped one like in deej 's PIC ...how much does a second hand tracker cost there lets say a 2006 ..
In srilanka the traker is known as D-traker nt a KLX and market differs frm the sensor CARB thing basically a RECONDITIONED traker (Unregistered) will cost around 345,000LKR (3400 USD )
Hmmmm...I might not be of much help then. This 'NT' thing seems to be a different animal. The newer KLX/D-Trackers that we get over here in Japan are pretty much the same as the U.S. spec bike.
Old Sep 11, 2008 | 05:49 AM
shan's Avatar
Smile
Originally Posted by Savagekilla
Shan, I'm from Sri Lanka too hehehe.. We'r the only two Sri Lankan guys on this site..
The only way to really know the Genuine Year of the bike is to, take off the right side plate (one which covers the exhaust) and then you will see a chart with the year and corresponding month.. Look at the last dot that has been stamped, and that will be the year your bike was manufactured....
Where did you buy your bike from? Kurunegala or Colombo?
THNX guys ...For the info specially tremor 38 .probably in a few weeks time ill be getting the bike . anyways ill check the other bikes and post more on the differnces and stuff .
Hey savage killaa ""Brother hood"" hehe . anyways i didnt still buy the tracker i found 2 good bikes but must go and confirm the years one is a TRACKER -D with the TPS system ACERBIS head light,Pro skill EXHAUST and many more i might get that bike most probably .so what are you riding ?
Old Sep 11, 2008 | 05:59 AM
Savagekilla's Avatar
I'm riding -
2007 KLX250
Suzuki Hayabusa 1300 (my dads).
Honda Cbr 1100xx (that is also my dads but i ride all of them)..
All our bikes are legal and the hayabusa and cbr were bought down with permits..
Shan go to kurunegala, they have good d-trackers there.. Theres a place called Sujeewa motors.. And to confirm the year of the bike, do what i told you, look at the right side number plate which covers the exhaust..
Old Sep 11, 2008 | 06:43 PM
WestOzKLX's Avatar
Originally Posted by tremor38
I would suspect so. The CDI PN is 21119-1533.
Now I'll bore you with more details.. The box itself has wire loom coming out of it that terminates in 3 separate connectors. On the Japanes bikes, it mounts by sliding the box into a square shaped rubber boot that doubles as a vibration damer. There are two slots in the rubber boot that slide over tabs on a metal bracket that mounts to the LH side of the airbox. This CDI is also a substitude for the original KLX250SR CDI which is no longer in production. It's night time, so I can't check it for any other markings right now...just going by memory.
Look familiar?
The state side model only has 2 connecters total and they are mounted to the side of the CDI (no wires coming out).
Stateside CDI maxes out at 25 deg adv from 5000 RPM up, reduces spark at 10,500 and completely cuts it off at 11,000rpm.
The CDI I have (and probably you have) gives you 35 deg adv at 5000rpm and above. The spark is still going strong at 12,000rpm and there's no limiter.
Oh, and if this CDI comes on Aussie bikes, here's another good reason to be happy...It costs the equivalent $300.00 USD for the CDI, the conversion harness and associated hardware goodies.
Just an update.
Reading my manual and I can confirm the AUS spec KLX250H7 has the 'good' CDI.
Quote from handbook.
"Ignition Timing. (Electronically advanced. ) 10o BTDC @1 300 RPM - 35o BTDC @ 5 000 RPM.
Old May 19, 2010 | 06:34 PM
eeprasad's Avatar
Default hello shan
I have a green color D Tracker 2006-7.
Are you going to buy? well
I used several Japanese bikes in last 2-3 years. This is the ideal bike for our (Sri Lanka) roads, petrol cost , and speed...
JoelThailand
Nov 17, 2016 10:18 PM
Richard Avatar
Apr 21, 2013 01:37 AM
Richard Avatar
Mar 13, 2013 03:53 AM
shan
Oct 16, 2008 10:02 AM
dieselmech
Feb 3, 2007 11:11 AM
