Just a random question
Old May 17, 2017 | 02:12 AM
bryan632's Avatar
Default Just a random question
I was sitting here thinking about engines and had a thought. When I was young, my dad and some of his buddies were hogging out a cam journal to install needle bearings. Never really thought much into it until I installed my big bore kit. Is there any horsepower to be gained from roller bearings in the camshaft of these small engines? I don't plan on doing any machining. I am just curious.
Old May 17, 2017 | 02:24 AM
Coopsklx's Avatar
not significant enough to warrant the work and cost
Old May 17, 2017 | 02:46 PM
My guess is if there were enough horsepower lost there (due to friction) to make a noticeable difference, they would melt down pronto. Just a guess though.
The mod has been discussed by others when journals failed due to lack of oil.
Old May 18, 2017 | 01:38 AM
Plain bearings run on a film of oil - extremely low friction with the kind of oils now available. Even the cheap stuff, considering the additive package in the blend.
Virtually all super sport bikes and muscle cars as well as the racing versions are running plain bearings. I guarantee you if and race team could eek out a 1% horsepower gain for racing they'd have ball or roller bearing crank or cam journals. It doesn't and they don't.
Old May 21, 2017 | 03:25 AM
jabara572's Avatar
probably not since most engines, even performance ones still use plain bearings for cams.
Now roller cams.... that is worth power, and why you have seen flat tappet cams phased out in automotive engines. Why its not done in bikes...probably cost and also packaging size
evil636
Sep 21, 2021 09:50 AM
cooper
May 27, 2008 10:01 AM
dcorlando
Feb 14, 2007 04:09 PM
frrogger1
Jun 17, 2006 04:29 AM
50 Slider
May 7, 2006 11:18 AM
