japanese cdi?
Old Sep 27, 2008 | 08:27 PM
dngrrngr's Avatar
Default japanese cdi?
I thought i remembered seeing a thread on here about the japanese klx's having a cdi unit with better ignition timing. when i used the forum search tool i could not find it so maybe someone can help. I have a 2007 kl250s that i have rejetted and done a uni filter on and am going to add a pipe and do the 13/45 gearing. my bike mostly gets ridden on the street and id like a more useable power curve (or even a power curve to start with). with that said where can i get a japanese spec cdi unit? will it even be worth it? what will it cost me? i am trying to get as much out of the 250cc because i dont have the money to upgrade for a 300/330 yet. thanks in advance
Old Sep 27, 2008 | 08:30 PM
kgwld1's Avatar
I have one it advances the timing and doesn't have a rev limit. It wasn't cheap.
Old Sep 27, 2008 | 09:05 PM
ddt1972's Avatar
I could probably find you one, I just need to know what year bike it comes from, or a part number to look for. I see them here going for around $100-150 used, so they are not cheap.
Dean, think you can use your language skills and find out what model bikes these "good" CDI's came on?
Old Sep 27, 2008 | 09:29 PM
lcpl0331's Avatar
what possible advantage could a different cdi provide? by advancing the timing on such a small thumper what would be the outcome? faster rev's? more tourque? more horsepower?
Old Sep 27, 2008 | 09:41 PM
ddt1972's Avatar
It makes more power by NOT changing the timing so much at lower RPMs I think. And it has a higher rev limiter, so you can pull longer. Someone out there knows, kgwld1? Dean? I am thinking of getting one to put on with my 331cc kit and jet kit, but they are over $100 used.
Old Sep 27, 2008 | 09:42 PM
kgwld1's Avatar
You can manually advance the timing also same point, I've done both,the klx300 has about 15 degrees advance more then what we have. It moves the torque and peak power curve around. to put it simply.
Old Sep 27, 2008 | 09:44 PM
ddt1972's Avatar
Mind if I ask what part number you have? I think this a wise addition to the 331 upgrade.
Old Sep 27, 2008 | 09:46 PM
kgwld1's Avatar
Off a older klx 250 I'm not sure of the #
Old Sep 27, 2008 | 09:47 PM
kgwld1's Avatar
Just not a bolt on it won't fit are bikes without a adapter harness
Old Sep 27, 2008 | 10:04 PM
ddt1972's Avatar
Well, mine is a 2001, so it is different already. If you could look for the number, I would appreciate it. It may be a direct bolt on for me.
