Ims tank leaking
Old Oct 12, 2011 | 09:58 AM
ducatiss750's Avatar
Default Ims tank leaking
Received my new tank today but I'm am unable to stop it leaking from the main outlet. Did anyone else have this trouble I replaced the normal larger o ring which is 10mm with the smaller supplied o ring but it still leaks tried the one the was standard still no luck even tried both together. O rings are not split please help
Old Oct 12, 2011 | 12:44 PM
Did you use it just on the tread or around the o ring I have tried all from just seated to locked down and it still weaps
Old Oct 12, 2011 | 01:24 PM
Blackheart58's Avatar
Try being much more gentle with tightening it down. If you snug it down too much, the O-ring deforms and is squished out from the surfaces....it's actually easy to see if you watch while you tighten it. Unless you've contorted your O-rings too much, it should still be usable.
Old Oct 12, 2011 | 02:45 PM
GaryC's Avatar
Loctite makes a product called PST.
it is a pipe thread sealant that is fuel proof.
That is what i used because i had the same problem with the "O" ring squish under light pressure. I didn't care for the fact that the fitting was just over finger tight to seal, and a little more tight it leaked.
Old Oct 19, 2011 | 11:11 AM
Angry Returning tank
Sending tank back to ims for replacement. After spending $50 on various sealers and new o rings I have not been able to stop leak. Had a mechanic mate blow compressed air into tank and spray around leak with soapy water , it appears leak is between brass insert and plastic surrounding it. Freight back to the states $75.00
Any one else had to send there's back .
Old Oct 19, 2011 | 06:33 PM
Illking's Avatar
I thought mine was leaking but I just didn't put the pinch clip on the fuel line / petcock on far enough no more gas scented garage.
Old Oct 19, 2011 | 08:30 PM
You're Number One!
(sorry about your problem...)
Old Oct 22, 2011 | 03:34 AM
JAC's Avatar
JAC
Mine hasn't leaked a drop.
bmwhd
May 31, 2017 05:06 PM
jglow
May 21, 2011 04:00 PM
fullmonty03
Mar 6, 2009 02:33 PM
1lowGMC
Ninja 250R
13
Oct 19, 2007 03:34 AM
a71busman
May 16, 2006 04:12 AM
