i got 2 questions about tires please
Old May 24, 2008 | 10:51 AM
loudoo76's Avatar
Default i got 2 questions about tires please
my trackmaster II's came last weekmy rear tireis 120/100, being that it is a tad bigger than stock is there a bigger tube i need? if so what size? and where can i get a nice set of spoons for making a easy tire change? thanks! and be safe this memorial day weekend!
Old May 24, 2008 | 10:59 AM
daveg's Avatar
Default RE: i got 2 questions about tires please
I would not use the stock tube- I would go to a heavy replacement tube. Also if you have a 250 you don't have rim locks. Add one you will be gald you did.
Also I alway match the tube size to the tire size, most people will say if it is close it is ok- but if one sze fit all- why would they make 30 differant sizes?
Old May 24, 2008 | 11:00 AM
daveg's Avatar
http://www.transworldmotocross.com/m...215768,00.html
good link on tire changing.
Old May 24, 2008 | 02:02 PM
Sid Post's Avatar
Get the Motion Pro long spoons. And, definitely get the heavier duty replacement tube. Rim locks are a good ideahowever, if you only use one and ride at highway speed you will need add a second rim lock or you will need to balance your wheel.
Old May 24, 2008 | 06:10 PM
espacef1fan's Avatar
Watch out..these TM2s handle ALOT different on pavement compared to the stock Dunlop 603s...LMAO...Just installed my TM2 today on the back...
Old May 24, 2008 | 10:03 PM
LearjetMinako's Avatar
A more correct size would have been the 120/90. And definitly get a new tube of correct size. Nothing sucks worse than having to do the work again if the tube is leaking.
If you are planning on running the tires below 20psi, then get 2xrim locks. I never run the tires below the 20psi so I don't use the rim locks. Haven't had a problem, yet!?
Old May 27, 2008 | 01:14 AM
oldphart's Avatar
Banned
motion pro sell nifty tire spoons that have the hex on the other end to loosen the axle nut.
Old May 27, 2008 | 03:05 PM
eas's Avatar
eas
I've got two sets of tire irons. 15" for using at home and 8" for carrying in my trail pack. If you're picky about how your rims look, get a set of rim protectors. Tie the rim protectors together with about 18" of string. You'll be glad you did. Spring for the heavy duty tube and rim lock(s) for front and rear. I get by just fine with one rim lock on each wheel, typically running 10-12 psi for trail use.
olderthandirt
May 3, 2009 07:17 PM
WestOzKLX
Apr 21, 2008 07:23 PM
Roadrage
Ninja ZX-10R
Apr 9, 2008 07:55 PM
MIninja600g
Feb 26, 2008 10:12 PM
DeFran
15
Jun 5, 2007 12:32 PM
