I called the shop
Old Sep 23, 2006 | 01:32 AM
  #51
Old Sep 23, 2006 | 02:41 PM
  #52
MaverickAus's Avatar
Default RE: I called the shop
ORIGINAL: Nobrakes
While there's plenty of information available on riding ruts cleanly, if anyone has any tips on rut recovery, i.e., what to do when you find yourself about to do down due to rut, I'm all ears.
Stay out of them [8D]
Go slow [&:]
Old Sep 26, 2006 | 01:41 PM
  #53
well guys it sounds like i had the same problem as deej... i think i let mine go longer and it was alot louder than yours deej, i called yesterday to get an idea when it will be done, the mechanic said that he ordered an exhaust cam which comes with the compression release. and he said the valve clearances are off so he is going to fix them too.. He said the parts usually take about 4 days to get so i should get my bike back end of this week or beginning of next week. It wasnt the bottom end like that other shop thaught, i was kinda wondering about that, cause if it was lower end it would make the noise all the time, but if i was above 5500 rpm's it was quiet, but from like 3500 to 5300 it was "ticking" really loud... i would have my damn bike back already if i would have taken it to this shop first, but noooo... that other shop had to screw around and do nothing for 6 days...grrrrrrr...... anyway... just letting u guys know whats up... so if your under 3500 miles keep an ear out if it starts ticking, good chances its the compression release, like mine and deej's...
Old Sep 26, 2006 | 02:59 PM
  #54
dazjr's Avatar
ORIGINAL: Nobrakes
This is the biggest reason I run the AC10 on the front of my bike. An aggressive front tire will hold your line better, it won't drop or slide into ruts. If you get in a rut, it will climb out with no drama. That AC10 has saved my bacon many times.
It's beginning to sound like we all need to stock up on exhaust cams. [>:] [] [:'(]
Old Sep 26, 2006 | 04:24 PM
  #55
ORIGINAL: EMS_0525
I am starting to think that there will be a recall or replacement for these soon. If not at least I will get 5 more at this rate for free. Looks like the 5 year warranty is gonna pay off pretty good.
Old Sep 26, 2006 | 04:26 PM
  #56
sure hope there is a recall or something... hopefully the part put back in will last longer than the original one.....
Old Sep 26, 2006 | 05:30 PM
  #57
ORIGINAL: dazjr
ORIGINAL: Nobrakes
Thanks for that dazjr. I'm running a trak master II front and rear and while I love the rear, I'm now su****ious of the front, so I've been doing a little research on this topic of a rut eating front tire. That Michelin AC10 looks pretty darn nice. Here's another one I've found that looks good also - Bridgestone E660 front.
Bummer about the exhaust cams, guys. Now every little noise my bike makes I'm going to be thinking - "exhaust cam!" [&:] Hopefully these are just two isolated incidents
Old Oct 24, 2006 | 06:25 AM
  #58
KYMER KLX's Avatar
I HAD A SIMILAR PROBLEM. BOUGHT THE BIKEAS A DEMO GOT A GOOD DEAL. RODE IT FORA WEEK AND IT STARED TO CHATTER. COMING FROM CLUTCH AREA, TORE IT APART, ANDFOUND THE OIL PUMP GEAR IN PIECES. TOOK IT TO THE SHOP, LUCKY ME SINCE IMTHE LEAD TECH AT THE SHOP. REMOVEDTHE CLUTCH AND FOUND THATMY CRANK WAS BENT, 100 MILES AND BROKEN, REPLACED THECRANKAND HAS NOT MISSED A BEAT SINCE. GOT OVER 1,000 MILES NOW.
Old Oct 24, 2006 | 06:52 AM
  #59
KYMER KLX's Avatar
HOLD IT WIDE OPEN AND RIDE IT OUT. I AM FAR FROM AN EXPERT BUT HAVE BEEN IN THAT SAME SITUATION. FULL THROTTLE AND HOLD ON AT LEAST U TRYED.
Old Oct 24, 2006 | 12:04 PM
  #60
kymer typing in capitals is considered shouting, just thought maybe you didn't know
cheers
