A humble question.
Old Feb 7, 2013 | 02:12 PM
Malves's Avatar
Renthal CR High on my bike. Throttle cable gets a lil stuck if I move the handlebar all the way to the left. I still have to re-route it. For clutch, I am using KLX300 clutch cable. It's 2" longer than ours and it has the same fittings. Do a search here and you'll find the part number.
Old Feb 7, 2013 | 03:26 PM
ol'klx-er's Avatar
KLX 300 clutch cable 54011-0009
Old Feb 7, 2013 | 03:39 PM
Mikeybb's Avatar
Originally Posted by TNC
Have you tried flipping the throttle assembly upside down to where the throttle cables are running under the handlebar instead of on top? I did this with my TM36 conversion which necessitated the cable to reach over to the left side of the carb. The design of the OEM throttle housing allows you to run it at any position of rotation that works for you, and it gives you more length/slack when turned upside down. At least it did on my '06.
Haven't tried this. I'll try it this afternoon when it warms up. Also, when switching bars, I just ground off the "pegs" on the plastic switch housings. So, what limits my throttle rotation now, because the housing can spin now?
Can anyone clarify if the KLX300 clutch cable 54011-0009 is 2-inches longer than stock for which bikes? 2006/2007, 2009+, s and/or sf models?
Old Feb 7, 2013 | 03:40 PM
chainslack's Avatar
If you go the custom cable route, Barnett like the clutch parts may be able to take care of you. I put taller (more upright) bars on on a suzuki bandit and they made the cables for me. Between 40-50$$ back before 2000.
Steve
Mikeybb's Avatar
Is the throttle cable longer as well? Thank you for the PN#.
Old Feb 7, 2013 | 03:43 PM
Mikeybb's Avatar
Steve
Thanks for the advice, Steve. I sent Motion-Pro an email on a quote for price and we'll see how that turns out. Also, I'm going to try TNC's way of doing it first because it's free.
Mike
Old Feb 7, 2013 | 03:47 PM
My housings don't have any pins anymore either. They clamp tight to the Renthal handlebar I have on my bike with just the screws in the housings...like most dirtbikes have done for many years.
Old Feb 7, 2013 | 03:51 PM
Mikeybb's Avatar
Mine can spin a bit. I'll just layer some tape or rubber to make the bar a bit thicker and call her good. I don't know much about any type of bike, but it's great to know that dirt bikes have run this setup in the past. Sorry if these are stupid questions, I've just never done this before and don't want to mess it up with my backwoods engineering abilities.
Old Feb 7, 2013 | 03:54 PM
ol'klx-er's Avatar
No idea. I had that PN on a sticky note for my "shopping list".
