Huge Problem...Engine died. Take a look at these pics
Old Jun 5, 2012 | 10:34 PM
  #81
RaceGass's Avatar
Better knock wood.....
Old Jun 5, 2012 | 11:19 PM
  #82
ns503's Avatar
And how many miles since?
Old Jun 5, 2012 | 11:55 PM
  #83
jhoffy22's Avatar
Surprisingly only about 1,500 miles since. Not much at all. Enough to make feel feel confident that the engine is solid.
Old Jun 6, 2012 | 04:27 AM
  #84
RobG's Avatar
So what happened? Did you redo it yourself or have somebody do it for you?
I was going to do my 351 myself... now I'm not so sure!!
Rob
Old Jun 6, 2012 | 04:58 AM
  #85
You can do it. This was my very first time into an engine and it turned out fine. Take your time, use the manual, do your research, ask questions, and follow torque specs.
Old Jun 6, 2012 | 11:02 AM
  #86
CousinLarry's Avatar
RobG - it's easy if you can read directions and don't guess on things like torque specs
Old Jun 6, 2012 | 12:35 PM
  #87
jhoffy22's Avatar
Rob:
1. Follow torque specs, make sure you understand torque sequence too.
2. Don't speed shift on a fresh top end with a high compression big bore. (Don't shift through the gears without ever letting off the throttle.
3. Don't do any camshaft modifications to an already close piston/valve clearance.
4. Follow the owners manual, and remember, installation is the reverse of removal. (haha)
Vokal389
May 4, 2008 08:15 AM
mendex187
ZZR 600
Apr 26, 2008 03:46 AM
Sick636
May 22, 2007 02:49 AM
NOLA500Ninja
Feb 18, 2007 04:39 AM
JETHRO980
Feb 15, 2007 10:06 AM
