How thick is the mixture screw plug
Old Apr 2, 2016 | 08:38 PM
DSRW's Avatar
Default How thick is the mixture screw plug
I'm installing a stage 1 dynojet kit on my 2011 klx250s and am at the step of drilling out the mixture screw plug. How thick is that plug? I don't think I've broken through yet but the hole I've drilled is almost 1/4" deep.
Thanks in advance.
Old Apr 2, 2016 | 09:07 PM
Brewster's Avatar
STOP DRILLING!! The plug is very thin.
Ride on
Brewster
Old Apr 3, 2016 | 03:15 AM
Ruggybuggy's Avatar
If you've gone 1/4" a new idle mixture needle might be needed. On another thought, are you drilling the wrong location?
Old Apr 3, 2016 | 11:39 AM
Werloc's Avatar
You musta went through right away and didn't know it cuz it's real thin and soft sheet metal. Most guys use a punch to poke through or a woodscrew without pre drilling. Sounds like your far passed that point. Hopfully you didn't do much damage and may get away with getting a new pilot screw and not the whole carb.
Old Apr 3, 2016 | 08:12 PM
DSRW's Avatar
Thanks everyone. I'll take the carb to the local machine shop and get this fixed. Fortunately it looks like all I've drilled is the brass so hopefully the carb is still ok.
Old Apr 3, 2016 | 08:23 PM
Ruggybuggy's Avatar
If not I do have a good carb with a dynojet kit already installed.
2k1w=no$
Jan 12, 2008 01:58 PM
gfoster
Sep 2, 2006 09:36 PM
Bad Bear
Aug 28, 2006 11:28 PM
krntl13
Jul 23, 2006 02:58 AM
ZX_9r
May 13, 2006 06:46 PM
