how to clamp cr style brake line.
Old Aug 28, 2016 | 03:47 PM
Matt88-8's Avatar
Mine was the exact same thing as your. Do you have the stock line? I sliced the plastic stiffer ofor the stock one and wrapped it in black tape over the new line
Old Aug 28, 2016 | 04:52 PM
Werloc's Avatar
I have an aftermarket stanless steel braided line that the PO installed. So I don't have the old stock one. I think Lowes has poly air tubing I can try if I can find the correct ID size.
Old Aug 28, 2016 | 07:47 PM
Matt88-8's Avatar
If you can't find one at Lowe's, try a truck shop. The airline they use would be the right stiffness. And they have lots of sizes
Old Aug 28, 2016 | 08:54 PM
I'd say try some thick wall shrink tubing. Take a look here at www.heatshrink.com and get a size like 3/4" ID that will shrink at 1:3, it will shrink from 0.75" to 0.25" ID.
Click on the data PDF link to see the full specifications. If it can slide over the fitting then shrink it down with a heat gun. It isn't cheap at around $10-11/foot with 4 foot length. Possibly an electric shop or doing a bit more searching can get it local and/or lower cost. Maybe 1/2 or 3/4 ID can slide over the fitting.
Old Aug 28, 2016 | 11:03 PM
Werloc's Avatar
Both good ideas guys. I do have a big truck stop about 30 minutes away that has everything. That heatshrink would be perfect to hold the slit opened air line, giving it a factory finish. Nice and clean, done the right way. Perfect....Thanks guys.
klx-vn
May 16, 2016 11:53 PM
KLXer
Mar 13, 2007 02:54 AM
YYY.GUY
Oct 31, 2006 04:39 AM
cwgoff
Oct 9, 2006 06:20 PM
klxstiffler
Sep 21, 2006 04:04 AM
