High altitude jetting help/ mods didn't make much difference?
Old Jun 25, 2009 | 06:44 PM
roadglider's Avatar
I meant adjust idle mixture screw. I really need to proof read before I post a reply.
Old Jun 26, 2009 | 11:06 PM
cjcrashesalot's Avatar
You may be right, I could be overthinking the situation. The problem is, this is my first dirtbike and first time doing any carb work, so I'm paranoid I will screw something up. I'm looking at every little nuance produced by the engine, which probably isn't helping.
Thanks for the info so far everyone!
Old Jul 24, 2009 | 04:52 PM
Just an update to my situation...
after experiencing some major bogging on steep hills at high elevation, I decided to go back down to the stock 118 main jet. I kept the DJ needle at the same clip. So far, there is a definite improvement. I've got to fix a few more things before I can take it on a long mountain ride, but I think I will have better luck. So just to document and help other high elevation riders, here are my settings:
Uni filter
Airbox lid removed completely
Stock exhaust
DJ needle, 2nd (3rd maybe?) clip from the top
Stock 118 MJ
Fuel Screw (Kouba T handle) 2 turns out
Slide Drilled
Elevation: 8000-12000
ARB
KLX300R
May 21, 2012 04:04 AM
Tmoe
Oct 14, 2010 12:22 AM
Desert Fox
Jun 2, 2008 05:10 AM
gmilbu
Feb 4, 2007 11:06 PM
Thunderchild
Sep 5, 2006 06:15 PM
