Help with raising forks
Old Dec 15, 2015 | 12:11 AM
Narfle's Avatar
Default Help with raising forks
So got my lowering links installed in the back no problem but the front is fighting me a bit. I loosened all bolts completely and smacked everything with a mallet - left fork leg came up nicely as far as it could (about an inch) but the right one only moved up slightly. I tried knocking the top triple with the mallet - nothing. I tried jumping on the bike - nothing. I locked down the left fork and then tried the same things - nothing. Anyone have advice before I go medieval on it? It would be a one person job unless the wife can help with it....
Thanks
Old Dec 15, 2015 | 03:24 AM
MaximusPrime's Avatar
If you have something that won't mar the fork legs, that you can also use to pry open the triples a tiny bit, it(the fork leg) should move easily. If not you have an issue.
Wait...
Is the front wheel still on? That will make life harder I think.
Old Dec 15, 2015 | 12:21 PM
durielk's Avatar
Get a bunch of screwdrivers. Stick the biggest blade that will go in the crack, in the crack and twist, spreading the clamps. While it is a little spread, stick a bigger driver blade in there. Repeat till it is loose. Put a piece of wood shim in there once you have it opened up.
Old Dec 15, 2015 | 12:33 PM
Narfle's Avatar
OK I'll try the screwdrivers maneuver. And yes, the front wheel is still on. If that doesn't work I guess I'll take off the wheel-
So when I'm done with this I just need to reset the sag - no need for new springs front or rear right...
Old Dec 15, 2015 | 02:03 PM
DYNOBOB's Avatar
I always loosen one leg at a time, grab it and twist it in the triple clamp, goes right up.
Old Dec 15, 2015 | 08:33 PM
rgmr250's Avatar
I've found the twisting works well on the different bikes I've worked on, from the KLX to a Goldwing. Once you twist it a little, it will move more easily. If you can't twist it at all - use the pry method to open the clamps up a little to see if that helps.
foggys916
Oct 5, 2007 05:24 PM
klxstiffler
Jan 7, 2007 12:55 PM
queenpdog
Oct 11, 2006 03:52 AM
kevlarian
Ninja 500R
Sep 22, 2006 04:41 AM
bkyee
Ninja 500R
Sep 4, 2006 11:17 AM
