Help with raising forks
So got my lowering links installed in the back no problem but the front is fighting me a bit. I loosened all bolts completely and smacked everything with a mallet - left fork leg came up nicely as far as it could (about an inch) but the right one only moved up slightly. I tried knocking the top triple with the mallet - nothing. I tried jumping on the bike - nothing. I locked down the left fork and then tried the same things - nothing. Anyone have advice before I go medieval on it? It would be a one person job unless the wife can help with it....
Thanks |
If you have something that won't mar the fork legs, that you can also use to pry open the triples a tiny bit, it(the fork leg) should move easily. If not you have an issue.
Wait... Is the front wheel still on? That will make life harder I think. |
Get a bunch of screwdrivers. Stick the biggest blade that will go in the crack, in the crack and twist, spreading the clamps. While it is a little spread, stick a bigger driver blade in there. Repeat till it is loose. Put a piece of wood shim in there once you have it opened up.
OK I'll try the screwdrivers maneuver. And yes, the front wheel is still on. If that doesn't work I guess I'll take off the wheel-
So when I'm done with this I just need to reset the sag - no need for new springs front or rear right... |
I always loosen one leg at a time, grab it and twist it in the triple clamp, goes right up.
Originally Posted by DYNOBOB
(Post 526132)
