Front Stainless Steel Brake Line for a 2007 KLX250S?
Old Mar 2, 2019 | 04:38 AM
Tank Girl Oz's Avatar
Originally Posted by AdventuresinRealLife
I'm working on a way to fix the 09+ Galfer front line to the 06/07. So far I've got the lines, the UFO guards, a Zeta brake line clamp, a line guide from the 09, and some plastic epoxy. I plan to try it in the next week or so, I'll make sure to let everyone know how it goes.
Guess it didn't go so well. I would like to know if this is possible.
Old Mar 2, 2019 | 11:06 AM
FWIW I reposted the CR wrap illustration the KLX650 guys did. You could test the length and path by using some cheap rubber or plastic tubing before having a line made up. As said, the KLX650 and pre-2007 KLX250/300 used the same general fork design where it involves brake lines and guards. I have a 650 and my brother has an 07 KLX250 and the fork similarity was the first thing I noticed.
Old Mar 3, 2019 | 09:12 AM
Thanks klx678. For some reason I missed that there were more comments in this thread. I'm going to a local company that can supply the Hel system with banjos. I'll remove the original and take it with me. Where there's a will there's a way!
Old Mar 5, 2019 | 12:09 AM
drm's Avatar
drm
I bought klx300 galfer lines when they had a sale for front and rear. Fit my 2007 fine once I rerouted the front
https://www.kawasakiforums.com/forum/klx-250s-71/2006-07-klx300-brake-lines-klx250s-43243/page4/#post525109
Old Mar 5, 2019 | 03:16 AM
Thanks drm, that's good info to know
Old Apr 1, 2019 | 01:25 AM
Matt88-8's Avatar
Dont forget that the fork gaurds have a slide over them, you simply cannot attach a clamp to them for the CR wrap. I added a SS line to my 07, it was a bit of an ordeal but it really works well.
Old Apr 1, 2019 | 01:36 AM
Matt88-8's Avatar
Old Apr 1, 2019 | 01:44 AM
The line could be zip tied to the fork guard by drilling two small holes for the zip tie to pass through. Make them a bit small, wobble the drill to slot them a bit, then insert the zip tie through the two holes so the tie is outside the guard. Keep the holes relatively close so the tie won't catch when the fork compresses.
I think the KLX650 guys cut the guard out a bit where the cable wraps back, that way they can put it in the channel of the guard.
vlodpg
Mar 5, 2019 12:13 AM
canehdian_guy
Jul 20, 2015 06:53 PM
Oldad
Mar 17, 2015 12:22 PM
DustyCowboy
Feb 2, 2013 12:38 AM
digitaloverkill
Jun 17, 2007 03:42 PM
