2nd/3rd gear bogging @7000rpm
Old Apr 3, 2019 | 01:56 AM
wetfootnelly's Avatar
Default 2nd/3rd gear bogging @7000rpm
Finally got out on some dirt but had a short stretch of 60mph road. I noticed 2nd and 3rd gear the bike started to chug/cutout/big down at 7k rpm. 4th and 5th gear were fine.. what's the dealio?
Bike is standard as far as I know aside from the core 4 pipe. 5000 miles.
Gracias
Old Apr 3, 2019 | 10:12 AM
klxnoobie's Avatar
What's year KLX? Is it fuel injected?
Old Apr 3, 2019 | 12:51 PM
philgoodklx's Avatar
Disable the rev limiter up by the clutch lever. This operates in the higher gears.
Old Apr 3, 2019 | 01:42 PM
No FI, ita a 2006
Old Apr 3, 2019 | 02:20 PM
Is your air filter clean? If so, this bike is probably not fueling properly. Try pulling open the choke/enricher lever and see if it gets better or worse. If better, it needs more fuel, and v/v.
The rev limiteer philgoodklx speaks of is not installed on our US bikes. You shouldn't find one to disable.
Old Apr 3, 2019 | 02:32 PM
brand new air filter with less than an hour on it. ill try the choke trick, if it needs more fuel what is the solution? rejet?
Old Apr 3, 2019 | 03:30 PM
Yep. rejet Possibly the pipe was stuck on w/o jetting.
Old Apr 3, 2019 | 04:03 PM
ok will start to research this.. first timer i am sure i can do it i'm pretty handy with tools, etc
Old Apr 3, 2019 | 06:59 PM
Re-jetting the carb is easy. Getting the carb out is the toughest part. Spend a little time looking over klxter's threads on it as he's explored more than most.
Is your airbox lid on or off?
Old Apr 3, 2019 | 07:59 PM
will do..
the snorkel is off but the lid is still on..
KLX_boy
ZZR 600
Nov 30, 2021 01:50 AM
oldfart_newrider
Nov 1, 2011 03:57 AM
zfrederick
800, 800 Classic & 800 Drifter
Jun 19, 2008 11:16 PM
trats
Ninja ZX-7R
21
May 9, 2007 05:19 PM
str8krewzn
Oct 26, 2006 04:40 PM
