Front Brake Question
Old Nov 15, 2007 | 11:44 PM
bryantjt's Avatar
Default RE: Front Brake Question
Reviving an old thread, I'm on RockyMountainATV with my debit card burning a hole in my pocket....Any issues with the Galfer line now that you've had it a while?
Old Nov 15, 2007 | 11:56 PM
ORIGINAL: bryantjt
Do a search and find Bill Blue's brake line mod. I think KLXer was the one who did it first here, though, independent of Bill. It basically takes the front brake lines and routes them to the inside of the fork where they are protected, and around the back of the brake. It's the same way KTM and others do it. It eliminates the exposed front area and the brake line going in front and under the fork. I think Craig (lcpl0331) has done this on his bike. Here, like this:
There's much less exposure to damage this way.
Old Nov 16, 2007 | 12:53 AM
bryantjt's Avatar
Thanks Brian, another thing I noticed is that the front rotor on my new (used) wheels is similar to your KTM in that its hard mounted w/out the rivets/slides like the stock KLX rotor. I'll have to get it mounted and double check fitment before I place my order in case I need a new rotor too...
Old Nov 16, 2007 | 01:17 PM
Truckman's Avatar
A while back a member here was posting that he was making some lines himself for the bike.He had prices posted and all.Remember the line has to be run in the MX sway of half thru the guard and then loops between the fork and wheel to the caliper.I had my local hydraulic shop make one out of parker 4 wire hose and the proper ends.....26.93 for the price..Parker 4 wire is good to 5000 psi which is way more than 4 of your fingers will ever produce.They also had the proper fittings in stock.It took the guys all of 10 mintues to measure and fit the line and make it then hand it off to me to stuff in the backpack.STILL from 40 mph in a parking lot and standing i can only hold the rear wheel off the ground a few inches near the end of the stoppie attempt.the main problem is the soft front suspension.which i will get fixed soon.
Old Nov 16, 2007 | 01:26 PM
so where do we find bill blues line? and this galfer line? and whats the price on both?
Old Nov 16, 2007 | 01:48 PM
Shadetree's Avatar
Eric,
Give Bill Blue a call at 316-640-3629. I have his lines front and rear and they're great. My brakes are as firm as can be now. You will need to spend the time to bleed them properly, but it's worth every minute. He even clocks the fittings for proper alignment. I would expectthat the other, quality suppliers do the same, but it's for sure with Bill's work.
Good luck.
Bill Dragoo
Norman, Oklahoma
Old Nov 16, 2007 | 01:52 PM
what do they run for the set?
Old Nov 16, 2007 | 01:58 PM
  #28
Shadetree's Avatar
Sorry, Eric. I bought mine sometime back and don't remember the cost. I guess I could try to dig it up, but call Bill. It was reasonable, I remember that. He's a great guy to get to know anyway. Watch out, though. He might sell you a steering damper...
You know you really want one, don't you?
Bill Dragoo
Norman, Oklahoma
Old Nov 16, 2007 | 08:10 PM
  #29
bryantjt's Avatar
Bill's lines were about $55, same for the Galfer. The Galfer however has a metal 90 degree fitting that sticks out beyond the forkleg, I don't remember what the BB lines were.
Old Nov 16, 2007 | 08:42 PM
  #30
55$ for both? thats not bad at all... another thing to add tothe winter list.....
