Fork oil replacement
Old Apr 12, 2013 | 03:46 AM
gravel eddie's Avatar
Default ......
Old Apr 12, 2013 | 12:31 PM
Malves's Avatar
Service manual here is your best friend. Take a look at a couple of videos on youtube to get an idea of the process and then follow the service manual. That's what I did. Easy job.
Old Apr 13, 2013 | 04:33 PM
Highbeam's Avatar
Unless you are the size of a small thai boy then yes, you are too heavy for oem suspension.
On my last ride, I bottomed out the forks at least three times so hard that the tire chewed on the fender. Same in the rear but that is much easier to handle.
Oh and I only weigh 165.
Old Apr 15, 2013 | 12:53 AM
eddie, it's not a matter of opinion or trying to give you a hard time...15wt oil in the KLX fork is way, way, way too heavy a viscosity. The compression damping will be way too harsh.
Old Apr 15, 2013 | 03:38 AM
go cytocis's Avatar
I second TNC on this.
If ALL you are trying to accomplish is prevent negative pitching under braking, I can see how the 15w feels like an improvement, but I'd suggest that it might be more pre-load or heavier springs you are actually after.
15w is at the heavy end of the spectrum even for street bikes. Running such a heavy oil off-road puts you at risk for cavitation and possibly even blowing fork seals.
LearjetMinako
Dec 17, 2019 08:05 AM
mudjunkie
Jan 20, 2008 03:33 PM
seximexi
Jun 28, 2007 06:11 AM
vurtle
Mar 31, 2007 08:37 PM
keevo
Apr 6, 2006 07:24 AM
