Fmf powercore 4 + header
Old Apr 7, 2018 | 06:20 AM
S2s's Avatar
S2s
Default Fmf powercore 4 + header
Just got a 09 250s, came with stock exhaust on the bike and a powercore 4 pipe and header too. Buddy said it melted a hole in the airbox and he had to replace it thats why he took it off and went back to stock. Found in searches that some peoples fit funny but not melting anything. Anyone heard of this? Could i wrap the pipe and maybe that could help? Stock looks like it sits pretty close too. Necessary to get the jet kit if i do put it on the bike? Thanks!
Old Apr 7, 2018 | 12:15 PM
Klxster's Avatar
How bout you put it on and don't let it melt your airbox ? Whether you melt your airbox, or not, is up to you.
Wrap? Help? No! - it'll come into direct contact with the airbox, or close what little gap there is - things to be avoided..
You must install the system successfully enough to avoid melting the airbox.
If you can't find proper clearance during install, you will need to provide the "correction" to the system. Tractor jack handles, crowbars, 6' pry bars, Vices to allow bending mounting flanges, etc, will do the trick - to bend and tweak the system enough to provide the needed clearance.
Better yet - do both. My FMF system could be installed with good clearances, I tweaked it to provide even more..
Who knows what has or hasn't been done to your '09's carb.. But with a stock carb and airbox, no rejetting is needed as no real increase in power levels will occur. You begin to unleash more power with a snorkle delete and DJ kit (2152 or 2206). Go all the way to about 24hp with lidless airbox and the DJ144/1N carb setup - for this, read the correct link below.
Old Apr 7, 2018 | 04:50 PM
S2s's Avatar
S2s
Originally Posted by Klxster
How bout you put it on and don't let it melt your airbox ? Whether you melt your airbox ,or not, is up to you.
Thanks!
Looks like the part of the snorkel that goes into the airbox is cut off. For now I will install the pipe, leave the snorkel as is and when my dj kit arrives ill take it out completely.
Old Apr 17, 2018 | 01:55 PM
azdeuce's Avatar
My FMF just ever-so slightly melted the corner of my air box... not a biggie... what was my blinker got a hole in the bottom.. again didn’t like those anyways.. went a tad smaller all is good... so yep got to put it on and fuss around with it... GL
djchan
Jan 5, 2013 04:14 PM
09klx
Apr 29, 2010 12:47 PM
frankb
Jan 18, 2010 05:14 PM
speedracer138
Aug 13, 2008 03:21 AM
patmandoo
Jun 11, 2006 11:21 PM
