First mod advice. *New*
Old Jan 28, 2020 | 07:23 PM
  #41
Klxster's Avatar
In the last analysis, if you are unable to deal with: possible vacuum leaks, fuel delivery issues, detailed carb internals inspection/troubleshooting, idle speed adjustments,
you may not have the skills needed to get your bike operating correctly on a timely basis..
Old Jan 28, 2020 | 09:47 PM
  #42
Klx_250s's Avatar
Messed with it some more today and took a video. Please see/ listen attached.
Watch "Klx 250 idle" on YouTube
I did spray some carb cleaner around the boots on both carb ends and there could have possibly been a small leak at the rear boot on the left side where I had to do a good bit of manipulating last time I took it out. Also thanks for your assessment but I plan to keep screwing with things =)
Old Jan 28, 2020 | 10:17 PM
  #43
What seems to be the problem?
Old Jan 28, 2020 | 10:28 PM
  #44
Klx_250s's Avatar
It lingers on deceleration. Also I haven't ridden it yet because its 36 degrees in ohio but the bike was definitely warm enough that the cooling system kicked on. I made it allot better today. Would most people find this satisfactory?
Old Jan 29, 2020 | 05:30 AM
  #45
dtrackermslazgromthailassi's Avatar
I have an efi.. but it seems fine enough. don't worry about it too much before you can ride it.
Old Jan 29, 2020 | 12:33 PM
  #46
Klx_250s's Avatar
If everyone's happy with this can I go ahead and add some mods?
Old Jan 29, 2020 | 01:48 PM
  #47
Klx_250s's Avatar
Old Jan 29, 2020 | 02:53 PM
  #48
Normal. May be intrinsic to the CV carb.
You're the only one who needs to be happy with your bike!
IMHO, I'd ride it for a while first before modding. But to each his own!
FMF makes good pipes. I went Q4 because to me loud sucks. And I waited until I found a used one on fleabay for about $150. If money is burning a whole in your pocket, get it.
Old Jan 29, 2020 | 04:27 PM
  #49
Klx_250s's Avatar
So the fmf is considered quiet? I was about to ask what the quietest option is that still gains performance.. Dont rly want my neighbors to know every time I take off from a stop. I'd rather have a klx300 system but I cant find one worth buying for the price.
Old Jan 29, 2020 | 06:42 PM
  #50
FMF makes two options. Look on their website.
The Q4 is quieter than the Powercore 4, and is probably the quietest aftermarket muffler available. Both flow better than stock.
