First impressions and road report
Old 04-07-2008, 12:59 AM
LimeDream's Avatar
Default First impressions and road report
Picked up my new 2007 KLX 250S on Friday!
OK, I might be a bit older than some of you. It has been 30 years since I sold my ~1968 Kawasaki 100cc dual purpose machine which I had converted to a "Dirt Digger".
Anyway, back to the future...
After studying up on the "very controversial" mototuneusa break-in procedures (http://www.mototuneusa.com/break_in_secrets.htm) that some of you have done on your bikes, I opted to go for it. Starting out today with 1.6 miles on the odometer and a fresh change to the recommended oil, I set out following the procedures to the tee. Fortunately I live in a rural area, soit was easy to findback roads, open stretches, and lots of corners to perform the aggressive accelerations and decelerations that this procedure calls for.
Wow, that was fun!! This bike really goes.Considering fun-factor, the mototuneusa method sure beats the manufacturer's recommended break-in procedure of "Driving with Miss Daisy".
After the prescribed 20 mile trek (which accomplishes 80% of the break-in), I garaged it and called it a day. Now I need to change the oil and filter to continue the next 20% of the break-in (over 1,500 miles).
Although it was tempting to tear up and down some dirt roads, I decided I better stay focused on the break-in, and keep it on pavement. After all, gotta save something for next time.
I read some postings on the forum about how to retain the spring in position while attemptingto insert the oil filter. I opted to lay the bike down in the grass, but wondered what the jury has determined about the "grease dab" method... any problems reported using clean bearing grease?
Also, I discovered the Fram CH6015 oil filter I bought was too long to allow the oil filter cover to seat properly. I also read some negative reports on the forum about Fram filters (this one had metal end caps like the original, but is made in Korea).
Great bike.
-LimeDream
Old 04-07-2008, 01:05 AM
Default RE: First impressions and road report
Congrats on the bike, and take a look at that helmet, matching green and everything. Awesome man.
Old 04-07-2008, 01:07 AM
lcpl0331's Avatar
i did the grease on the end of the spring thing for a few changes and didn't encounter any problems. since i expanded the end of the spring it stays inside there all by itself. i haveused that 6015 filter since the bike was new and have not had any problems with it.
Old 04-07-2008, 01:37 AM
shaydara's Avatar
Welcome and congratz on the bike!! You never too old to ride. Hope all goes well for the future!!
Cheers!
Old 04-07-2008, 02:19 AM
Sid Post's Avatar
Welcome! Enjoy your new ride.
Old 04-07-2008, 02:24 AM
mudjunkie's Avatar
Note: when changing your oil, be sure to put the oil cover back on the same way...I believe it can be rotated 180 degrees and still go on, but the oil passage holes will not line up....just something I noticed when changing my oil.
Old 04-07-2008, 10:56 AM
LimeDream's Avatar
All, thanks for the welcomes, congrats, and oil filter tips!
lcpl0331, interesting idea on expanding the bottom loop of the oil filter spring... that'll be my first mod. Hmm, I will try another Fram CH6015. Perhaps this one was an odd ball.
mudjunkie, roger on not flipping the oil filter cover. I saw that too and thought what a wonderful place for a goof proof "can't assemble it wrong" design feature! Probably the same guy who designed the spring that falls out when inserting the oil filter.
-LimeDream
2007 KLX 250S
2003 Honda XR80
1975 Cessna Cardinal
Old 04-07-2008, 11:44 AM
DUDE, is that a minivan!?!!??! Do you drive a minivan?? hahaha.......... just messin man....
Old 04-07-2008, 11:48 AM
On the break in....man some people really put too much thaught into stupid things.... My dad used to drag race and has been a mechanic his whole life, and i asked hime how he broke in a new motor.... He said when he built the 350, many times, in his Nova drag race car, he would just drive it down the track like it was an old motor and that was it, didnt do anything special.... man, just ride guys.... no offense to you.
Old 04-07-2008, 12:22 PM
LimeDream's Avatar
ORIGINAL: EMS_0525
That's pretty funny. You're on to me... No actually, in the pix you can't see the nose it is a a Honda Pilot, a "guys minivan".
Quick Reply: First impressions and road report
