a few more goody's
Old Jan 4, 2008 | 02:21 PM
redbrd's Avatar
Default RE: a few more goody's
ORIGINAL: Harder12
*drool*
hey where did you get the tail light and headlight from?
hears a link for the tail light
http://www.wheelingcyclesupply.com/s...&cat_id=72
like tremor said the headlight is from a KLX 450.
it went on pretty easy i had to make three bracket's out of aluminum
as for the Vapor the back light is very bright you wont be disappointed,
i was very impressed with the quality of the whole package.
but just a note.... if you are going to get the dashboard with the light's don't get the protective pod... it wont fit.
and I think some guy's did reset the mileage i just don't know how.
Old Jan 4, 2008 | 09:10 PM
ORIGINAL: redbrd
I fabbed up a little motor contraption with a magnet and let it spin next to the odo sensor as fast as the vapor could reliably read it for the required amount of time to get the mileage right.
Hey, would you look at that ... proof that I had the fastest KLX ever.
Old Jan 5, 2008 | 01:32 AM
rkutzner's Avatar
What rear fender did you use with the edge 2 light? That rear is just AWESOME and I would like to flatter you by copying it....
Old Jan 6, 2008 | 12:03 AM
redbrd's Avatar
ORIGINAL: rkutzner
The fender is from Maier, it's for a KLX 300 but it goes on no problem.
that is what this forum is all about sharing ideas and helping out.
Old Jan 6, 2008 | 03:44 AM
mudjunkie's Avatar
redbrd,
do you have a pic of the rear fender before it was installed? I have browsed a few in the catalogues, but it's hard to tell what the fender actually looks like on the shelf, the brandsI can orderfrom list enduro, mx, etc soI want to make sureI order the correct style...would love to get my hands on the Maier, but I can't seem to find it in my neck of the woods
Old Jan 6, 2008 | 04:20 AM
KLXer's Avatar
ORIGINAL: mudjunkie
redbrd,
http://www.denniskirk.com/jsp/produc...;mmyId=4500013
Old Jan 6, 2008 | 04:09 PM
rkutzner's Avatar
Redbrd, how much of that rear subframe did you cut off? Did you weld any extra support for the lightswhen you cut off some of the old metal ? I'm thinking of tacking something under the fender to bolt the light to so there are no bolts above the fender. This could turn into a really fun project with obvious spectacular results. Thanks again for the info !
Do you have an exact part number for that fender. I did some searches on the KLX300 and the pictures I come up with look more like MY rear fender. They also seem to list 97-2002 seperately from 2003-up. Sorry to be a pain......
Old Jan 6, 2008 | 04:37 PM
  #28
rkutzner's Avatar
FOUND IT on Maier's site, DUH. MX style....Part number 14541
Old Jan 6, 2008 | 04:50 PM
  #29
ORIGINAL: rkutzner
Check out the Baja Designs tail light and plate holder. It bolts up under the MX fender. Cut the sub-frame near the bend and move the original plastic end caps to the cut-down section. I liked the brightness of the stock blinkers so I made a simple mount to keep them, just a single piece of 1/8" by 1" aluminum bent along the inside contour of the rear fender and turned up and the ends.
Old Jan 6, 2008 | 06:32 PM
  #30
rkutzner's Avatar
Great to see you still hangin' out with us, NoBrakes ! Enjoying that Katooom?
I was sitting down reading cycle world and they did a little writeup on these 'crashproof' breakaway lights:
http://www.electrosport.com/electros....product1.html
Supposedly brighter, much smaller, and even have backside indicators at the tip. They liked them and for $30 a pair I'm gonna order up a set, I think they'll go nice with that fender. I'll probably fab something up to us that hole that it looks like you may have (??) plugged up with something else. Too bad that rear fender isn't like 4 inches shorter...that would look killer.
jhoffy22
May 26, 2016 07:48 AM
Frontier
Nov 17, 2009 04:46 PM
EMS_0525
Nov 15, 2007 10:00 AM
Bake
Feb 19, 2007 04:13 AM
2001ninjaZX6R
Jul 19, 2006 09:45 AM
