EFI Idle problem
Old Jul 16, 2012 | 04:19 AM
alric's Avatar
Default EFI Idle problem
My Idle doesnt stay where it should now.
If I set it at 1400rpm it drops too low and stalls, so I set it about 1700rpm, but it varies a lot.
It was working well a couple of months ago, but I played with the subthrottle sensor setscrew, and ran it without some sensor for a while, and with an electronic box and 2bros juicebox etc,
Anyone know how to fix it?
I tried to reset the subthrottle sensor many times, with a voltmeter, it's about 5.9v now.
Do I need to manually close the throttle valve when I set the subThrottle sensor? How would I do this?
What else will make the idle fluctuate?
Old Jul 16, 2012 | 06:28 AM
Pogiboy's Avatar
If efi on bikes the same as cars, try removing the battery for 15 minutes. That should reset the computer. This might be a stupid advise though.
Old Jul 16, 2012 | 01:01 PM
JoelThailand's Avatar
Have you taken out the secondary butterfly? This can cause problems with the TPS at idle.
Old Jul 17, 2012 | 03:25 AM
alric's Avatar
Yes but it didnt cause problems for others who did the same.
Do you know why?
Is it to do with setting the subthrottle sensor signal?
I cant do that electronically
Old Jul 17, 2012 | 03:35 AM
Pogiboy's Avatar
Have you tried removing the battery for 15 minutes? It might reset everything to factory just like my tacoma.
preload
May 24, 2021 02:58 AM
thekeeper199
Jul 30, 2014 09:02 PM
MikeA12
Jan 24, 2007 05:11 PM
Sublime
Aug 20, 2006 04:08 AM
txredneckmedic
Apr 22, 2006 07:32 PM
