EFI to Carb conversion.
Old Jun 20, 2017 | 02:04 AM
Subseageorge's Avatar
Default EFI to Carb conversion.
Question for you guys out there?
If i were to convert from EFI to Carb, What would be the best Carb to purchase, I have a 331 BB kit installed , Ported head, 1" bigger inlet valves. FMF power bomb header and Q4 slip on,(In fact I have several local made exhausts that came with the bike with much bigger ID header and slip ons but very noisey)
I purchased a lot of parts for my rebuild and it turns out some of the more expensive items are for a carb bike. IE Programable CDI, IMS tank, my head is another one. lol
I am thinking it would be cheaper to fit a carb than replace the IMS tank alone.
Any way , What would be the best carb to use?
What issues would i have with disconnecting the ECU and running a Paray CDI , instead?
Your thoughts as always are the most valuable asset i have regarding information on my KLX.
Thanks
George
Old Jun 20, 2017 | 02:50 AM
wildcard's Avatar
No idea what kind of issues you may have going from EFI to carb, but I believe we had some members here in the past that did just that.
The Mikuni TM 36-68 pumper carb will probably give the best performance, but will likely require more tuning time than the stock CVK 34 as less people have used that carb and even fewer have really put the bike on a dyno with that carb. Also I don't know if anyone has compared back to back the TM36-68 to the CVK 34 utilizing klxster's "fat main, dropped needle" method of jetting.
The TM 36-68 is also a pretty expensive carb at ~ $280 USD where you could probably find a CVK 34 for a few bucks.
Old Jun 20, 2017 | 02:55 AM
RageHardIntoTheBendies's Avatar
With the money you spent on the
Headwork i'd definitely go with a pumper. You can email the guys at PaRay with questions they have great customer service
Old Jun 20, 2017 | 03:26 AM
durielk's Avatar
To do all that work and not go with a slide carb if your converting would be lunacy. The instant response is amazing, and then you have all the porting for the high end.
Old Jun 20, 2017 | 04:08 AM
Thanks guys, Still sitting with my bike in bits waiting for Racetech to respond to my many queries after they cocked up and sent me the wrong valves, but will not exchange them or tell me how to set up, the ones i was sent, so lots of thought time on my hands. Sounds like the Mikuni TM 36-68 is the one everyone is most happy with.
Old Jun 28, 2017 | 03:50 PM
reinigef's Avatar
I believe Bill Blue (B&B Restoration) sells a 33mm pumper bored out to 34mm.
Page 2. Just another option... which carb is too much or too little (especially with a ported head) I surely don't know...
"http://bandbcyclerestoration.com/Page_2.html"
Freddie
Neaty99
Mar 19, 2021 11:09 AM
armycopter
Feb 26, 2009 12:14 PM
bikerdc17
Jan 29, 2009 12:47 PM
roxryd
May 17, 2007 04:38 AM
ZX12Rider
Feb 22, 2005 03:11 AM
