dynojet 2 or 3 washers?
Old Apr 16, 2011 | 04:27 PM
Ckahleer's Avatar
Default dynojet 2 or 3 washers?
I am installing the Dynojet kit on my 09 KLX250s today.
The instructions say put the small washers above the clip on the needle.
The kit came with 3 washers. The fig. A diagram shows 2 washers.
Do I use 2 or 3? Thanks
Craig
Old Apr 16, 2011 | 04:35 PM
Highbeam's Avatar
Follow the diagram. They include extra washers in the kit just in case you want to do some custom tuning.
Old Apr 16, 2011 | 04:38 PM
03rubicon's Avatar
Is there a problem if you don't use any washers?
Old Apr 16, 2011 | 06:47 PM
The needle can bounce or wiggle around a bit more. Surprisingly most bikes don't go to pot completely without those washers...don't ask me how I know over numerous KLR's and KLX's over decades,LOL!...but there is often an inconsistent surge or power delivery without them.
Old Apr 17, 2011 | 02:14 AM
KLXHunter's Avatar
HB is right. Follow the directions. Becareful, I just did mine (2010) carb. I stripped one of the screws on the bottom of the carb. Ended up using a hacksaw to cut into the screw head to make it flat...got lucky and it came out. I had spare screws hanging around and one matched perfect. Also make sure you take the smog **** out. Go to Advance Auto or Napa and get vacuum cap assortments, about 6 bucks....
Old Apr 17, 2011 | 02:15 AM
KLXHunter's Avatar
also i dropped the ball and didnt order a .018 in drill bit. i went to three places.... i will end up pulling the carb at a later date....but the bike started up a lot better after being jetted. i also used fresh fuel..
Old Apr 18, 2011 | 04:19 PM
WhiskeyTF's Avatar
I compared their two washers and e-clip stack to the stock needle and the shoulder on the stock needle was thicker. I used all 3.
Old Apr 18, 2011 | 07:20 PM
Highbeam's Avatar
Don't you think that, just maybe, dynojet wants two washers there so that the needle will set closer to the main jet? By putting three washers in there you have made the needle sit out of the jet farther making it richer than designed.
Old Apr 18, 2011 | 07:38 PM
WhiskeyTF's Avatar
http://www.dynojet.com/pdf/2152.pdf
According to their documentation the washers go on top of the clip, not under. They have no affect on the location of the needle, they're just there to take up the space left from the thin e-clip.
Now.... you technically *could* put one under the clip to achieve about a half-notch change in height...
Old Apr 18, 2011 | 11:39 PM
Highbeam's Avatar
Well then cripes, it matters not. I recall how odd it was that with only two washers the little white chair legs did not rest on the black slide. I was being sure that I didn't block the air hole with the chair legs but then noticed that it didn't matter.
So the extra third washer will only preload the slide spring a tad more than it would have been.
