dynojet 2 or 3 washers?
I am installing the Dynojet kit on my 09 KLX250s today.
The instructions say put the small washers above the clip on the needle. The kit came with 3 washers. The fig. A diagram shows 2 washers. Do I use 2 or 3? Thanks Craig |
Follow the diagram. They include extra washers in the kit just in case you want to do some custom tuning.
Is there a problem if you don't use any washers?
Originally Posted by 03rubicon
(Post 443014)
HB is right. Follow the directions. Becareful, I just did mine (2010) carb. I stripped one of the screws on the bottom of the carb. Ended up using a hacksaw to cut into the screw head to make it flat...got lucky and it came out. I had spare screws hanging around and one matched perfect. Also make sure you take the smog **** out. Go to Advance Auto or Napa and get vacuum cap assortments, about 6 bucks....
also i dropped the ball and didnt order a .018 in drill bit. i went to three places.... i will end up pulling the carb at a later date....but the bike started up a lot better after being jetted. i also used fresh fuel..
Originally Posted by Highbeam
(Post 443013)
Don't you think that, just maybe, dynojet wants two washers there so that the needle will set closer to the main jet? By putting three washers in there you have made the needle sit out of the jet farther making it richer than designed.
(Post 443131)
According to their documentation the washers go on top of the clip, not under. They have no affect on the location of the needle, they're just there to take up the space left from the thin e-clip. Now.... you technically *could* put one under the clip to achieve about a half-notch change in height... |
Well then cripes, it matters not. I recall how odd it was that with only two washers the little white chair legs did not rest on the black slide. I was being sure that I didn't block the air hole with the chair legs but then noticed that it didn't matter.
So the extra third washer will only preload the slide spring a tad more than it would have been. |
