dual question (jetting and swapablity of parts)
Old Oct 14, 2009 | 09:13 PM
punkenduro09's Avatar
Default dual question (jetting and swapablity of parts)
1. stock jug, full pipe, no air box lid, 128 main, stock pilot, fuel screw 2 1/2 out. normaly ride ~1000-1500 feet, so cal desert, but want it to run up to 7000 atleast. im about to go on another trip, and was thinking of droping to a 125 main, and going up on the pilot (stocks 30 as i recall, so 35?), what do you think (bike has a pop, mid rpm on decel).
2. just found these guys in the new motosport catalog, http://www.devolracing.com. ive wanted to put disk guards on my bike, i know they make a rear (scott's), but i want a front. is there another bike like the kx or something that has the same front brake set up so i can run one.
thanks for your help
Old Oct 15, 2009 | 01:23 AM
lcpl0331's Avatar
Look into a kdx rotor gaurd. The wheels are the same so it might work.
The 128 main should be fine. A 35 pilot will work but you'll have to reset your fuel screw. 2 1/2 will most likely be too much.
Old Oct 15, 2009 | 06:51 AM
fgk228's Avatar
here in aussie land, the klx come stock with a #132main so by aussie standards your lean, the back fire or pop i would say because of your pipe, dont worry about it your jets are fine
Old Oct 16, 2009 | 10:51 AM
thanks for the replys. i think pending more replys and research if ill switch the pilot or not. im going to look up the kdx idea right now. seams like it would work.
Old Oct 16, 2009 | 03:47 PM
WestOzKLX's Avatar
Try this. It's in Japanese, but you'll get the idea. I think the part is for a KDX.
http://www.batta8491.com/klx.html#
Old Oct 18, 2009 | 07:16 AM
MaverickAus's Avatar
http://www.devolracing.com/KDX-200220_c_459.html
will more than likely work, no promises
smontalvklx
Oct 24, 2014 01:53 PM
Pauls2ndblessing
Dec 13, 2012 07:23 PM
redpillar
Dec 2, 2010 04:30 PM
Kobrakriss
Jul 24, 2010 04:13 AM
zerotanz
May 23, 2009 05:43 PM
