Drilling spoke holes larger?
Old May 15, 2017 | 09:06 PM
MaximusPrime's Avatar
Default Drilling spoke holes larger?
Is it safe to drill my rim to accommodate a larger nipple size?
I think the stock nipples are 6mm and I have a set of 8mm.
Old May 16, 2017 | 03:34 PM
You need to check to make sure the spoke is not also larger. I don't see much benefit from the larger nipple alone, except a slight bit more flat when tightening.
If you drill you need to try to make sure you are drilling in the direction the original hole is aligned.
I know somewhere along the line Kaw had heavier gauge spokes, don't remember if it was early or late models.
Old May 16, 2017 | 04:54 PM
I'm going to try drilling on my bad rim first.
If that goes ok, I'll drill the good rim and then I can get to lacing the wheel.
Riding season is here and my bike is on the jack.
Old May 17, 2017 | 02:45 AM
Coopsklx's Avatar
On my 2014 klx250s the spokes are 4 mm pretty heavy duty, the older ones were 3mm
Notstock
Oct 11, 2006 06:13 AM
Nobrakes
Jul 16, 2006 11:42 PM
Wannabe250
Jul 8, 2006 05:34 AM
NavKLX
May 22, 2006 09:24 AM
mr2turbo
Mar 18, 2006 09:15 PM
