Difficult to start.
Old Oct 31, 2022 | 10:40 AM
A 2010 bought in 2005? I think there was a typo. It helps if you go to the settings and at least list what country you live in. I know EFI was in Europe a few years before the U.S.
If you haven't tried it, drain any fuel and put in fresh fuel. Also consider trying some injector cleaner additive in the gasoline. Just some thoughts. For pressure and such you'll probably be better off spending the money at a dealer to have it checked out.
Old Oct 31, 2022 | 10:42 AM
cycloholic's Avatar
Originally Posted by klx678
Bought in 2005? I think there was a typo.
​​​​​​OH, 2015, you are right! Thinking to start with a cleaner!
Old Nov 13, 2022 | 05:21 PM
Cubdriver's Avatar
When a KLX sits for a while, the gasonine in the float bowl loses its volatile elements, and it will not start. Get a 3mm hex wrench and loosed the little screw and let a bunch of gasoline drain out, like a couple of ounces. Try it again. Make sure the gas in the tank is not too old also.
Old Nov 13, 2022 | 05:25 PM
cycloholic's Avatar
The motorcycle is running the last month or so, the old gasoline has been consumed.
Old Nov 13, 2022 | 05:47 PM
bmart's Avatar
I've found that I just get crappy fuel right out of the pump, even though I spring for E-free for the carbed '09. It actually wouldn't run at all ~4 miles from fillup last week. Did the drain the float bowl trick and it was like new. Water in the fuel...again. I ordered a 10 pack of 3mm ball end (~$1) to keep around the bike and garage!
Old Nov 14, 2022 | 01:07 AM
durielk's Avatar
I wouldn't go back to that gas station. ... and he has FI, not a carb.
Old Nov 16, 2022 | 08:54 AM
cycloholic's Avatar
So far, what i understand, is that it needs some time until it can start again. Its like a kind of electric relay that needs to start first and then it can start. Any ideas about that?! So usually when i close the switch, open it again, wait a bit and then start, usually it starts. If im on traffic light and accidentaly turn off the motor and try to start it imideately, then it sucks!
Old Feb 4, 2023 | 12:06 PM
cycloholic's Avatar
So far not any progress!
have used an injection cleaner but still nothing.
The ****ing bike is so hard to start it makes me crazy. if i use it for everyday purposes, the battery empties after a week or so.
Old Feb 4, 2023 | 12:19 PM
greychinos's Avatar
It's EFI.
Old Feb 4, 2023 | 12:21 PM
greychinos's Avatar
Does it burn oil? And how often are you changing the oil? Wonder if your rings are worn and lowered compression is the culprit.
